Analyzers
5285 Discussions
Parallelization (where and how to start?!)
vahid_a_1
Dear All,
I analyzed my code using adviser recently and this is a snapshot of the code performance. I am including the portion of the code which causes tremendous slow down here. Can someone give me a couple of hints and examples to start correcting the code?!
Source code :
2473            !$OMP PARALLEL default(none) &    36.706s    11.29%
2474            !$OMP private(i,j,n,k,kk)    & !! indice for Do loop
2475            !$OMP private(p11,p12,p13,p14,p21,p22,p23,p24) &
2476            !$OMP private(p31,p32,p33,p34,p41,p42,p43,p44) &
2477            !$OMP private(c11,c12,c13,c14,c21,c22,c23,c24) &
2478            !$OMP private(c31,c32,c33,c34,c41,c42,c43,c44) &
2479            !$OMP private(cs11,cs12,cs13,cs14,ci21,ci22,ci23,ci24) &
2480            !$OMP private(cl31,cl32,cl33,cl34,ce41,ce42,ce43,ce44) &
2481            !$OMP private(PHIC051,PHIC052,PHIC053,PHIC054)         &
2482            !$OMP private(PSI11,PSI12,PSI13,PSI14)                 &
2483            !$OMP private(APK1,APK2,APK3,APK4)                     &
2484            !$OMP private(ph,pdx,pdy,pc,pd,ome_nkk,ome_kkk)  &
2485            !$OMP private(pxxk,pxxkk,pxxp)                   &
2486            !$OMP private(del_psum1,result,result1,TIME)     &
2487            !$OMP private(ick,msn,nop,pkk,psum1,psum22,ptot) &
2488            !$OMP private(pxxary,pxxn)                       &
2489            !$OMP shared(csn_s,dt,dx,epsgb,epsk,epsl,epss,gc3s,gc6s5,gcu_l) &
2490            !$OMP shared(gcu_s,gsn_l,gsn_s,l0l,l0s,l1l,l1s,l2l,ml,ms,omegb) &
2491            !$OMP shared(omek,omel,omes)                      &
2492            !$OMP shared(weight,eptime,eptime1,freq,zi,ei,kb) &
2493            !$OMP shared(ZEKT,EKT,EPQ)                        &
2494            !$OMP shared(am,ck,cn,dfk,eps,eps_kkk,eps_nkk,fk,fn) &
2495            !$OMP shared(ome,pa,pb)                              &
2496            !$OMP shared(CS05I,CS05J,CE05I,CE05J,CI05I,CI05J,CL05I,CL05J) &  !! Input outside from parallel zone
2497            !$OMP shared(SUMIMC,NNN,NNN1,aa)                         &       !! Input outside from parallel zone
2498            !$OMP shared(ce,ci,cl,cs,DDDI,DDDJ,PHI05I,PHI05J,SSSI,SSSJ) &    !! Input outside from parallel zone
2499            !$OMP shared(APV1,APV2,APV3,APV4,APV11,APV21,APV31,APV41)   &
2500            !$OMP shared(c1,phi1,c2,phi2,psi,Exc,Eyc,Ex,Ey)
2501            !$OMP Do
2502
2503            DO I=0, IG, 1            0.961s    0.19%
2504                DO J=0, JG, 1
2505
2506                    !***** CALCULATE NEXT PHI VALUE *****
2507                    NOP=0
2508
2509                    DO N=1,NPP    0.072s    0.02%    0.472s    0.09%
2510                        IF (PHI1(N,I,J).GT.0.0) THEN    0.032s    0.01%
2511                            MSN(N)=1
2512                            PXXARY(N)=(PHI1(N,I+1,J)+PHI1(N,I-1,J)+PHI1(N,I,J+1) &    0.040s    0.01%            Divisions
2513                            +PHI1(N,I,J-1)-4.0*PHI1(N,I,J))/(DX*DX)    0.042s    0.01%
2514
2515                        ELSEIF (PHI1(N,I,J).EQ.0.0.AND.PHI1(N,I-1,J).GT.0.0) THEN    0.146s    0.04%    0.961s    0.19%
2516                            MSN(N)=1
2517                            PXXARY(N)=(PHI1(N,I+1,J)+PHI1(N,I-1,J)+PHI1(N,I,J+1) &
2518                            +PHI1(N,I,J-1)-4.0*PHI1(N,I,J))/(DX*DX)
2519
2520                        ELSEIF (PHI1(N,I,J).EQ.0.0.AND.PHI1(N,I,J-1).GT.0.0) THEN    0.070s    0.02%
2521                            MSN(N)=1
2522                            PXXARY(N)=(PHI1(N,I+1,J)+PHI1(N,I-1,J)+PHI1(N,I,J+1) &
2523                            +PHI1(N,I,J-1)-4.0*PHI1(N,I,J))/(DX*DX)    0.008s    0.00%
2524
2525                        ELSEIF (PHI1(N,I,J).EQ.0.0.AND.PHI1(N,I+1,J).GT.0.0) THEN    0.034s    0.01%
2526                            MSN(N)=1
2527                            PXXARY(N)=(PHI1(N,I+1,J)+PHI1(N,I-1,J)+PHI1(N,I,J+1) &
2528                            +PHI1(N,I,J-1)-4.0*PHI1(N,I,J))/(DX*DX)
2529
2530                        ELSEIF (PHI1(N,I,J).EQ.0.0.AND.PHI1(N,I,J+1).GT.0.0) THEN    0.070s    0.02%
2531                            MSN(N)=1
2532                            PXXARY(N)=(PHI1(N,I+1,J)+PHI1(N,I-1,J)+PHI1(N,I,J+1) &
2533                            +PHI1(N,I,J-1)-4.0*PHI1(N,I,J))/(DX*DX)
2534                        ELSE
2535                            MSN(N)=0
2536                            PXXARY(N)=0.0    0.030s    0.01%
2537                        ENDIF
2538
2539                        PHI2(N,I,J)=PHI1(N,I,J) ! only phi in interface region will be updated.    0.118s    0.04%
2540                        NOP=NOP+MSN(N)          ! number of coexisting phases at a grid (i,j).    0.108s    0.03%            Type Conversions
2541                    END DO
2542
2543                    !********************************************************************************
2545
2546    108             IF(NOP.GE.2) THEN
2547                        ICK=0
2548
2549                        DO N=1, NPP
2550                            IF(MSN(N).EQ.1) THEN    0.062s    0.02%    0.110s    0.02%
2551                                PXXN=PXXARY(N)  !(PHI1(N,I+1,J)+PHI1(N,I-1,J)+PHI1(N,I,J+1)+PHI1(N,I,J-1)-4.0*PHI1(N,I,J))/(DX*DX)    0.060s    0.02%
2552
2553                                IF(N.EQ.1) THEN
2554                                    CN = CS(I,J)
2555                                    FN = FS(CN)    0.024s    0.01%
2556                                ELSEIF(N.EQ.NPP) THEN
2557                                    CN = CL(I,J)
2558                                    FN = FL(CN)
2559                                ELSEIF(N.GE.NPPK.AND.N.LT.NPP) THEN
2560                                    CN = CI(I,J)    0.032s    0.01%
2561                                    FN = FI(CN)    0.064s    0.02%
2562                                ELSE
2563                                    CN = CE(I,J)    0.012s    0.00%
2564                                    FN = FE(CN)    0.054s    0.02%
2565                                ENDIF
2566
2567                                PTOT = 0.0    18.852s    5.80%
2568
2569                                DO K=1, NPP
2570                                    IF(K.NE.N.AND.MSN(K).EQ.1) THEN    1.304s    0.40%    173.496s    34.85%
2571                                        PXXK=PXXARY(K)   !(PHI1(K,I+1,J)+PHI1(K,I-1,J)+PHI1(K,I,J+1)+PHI1(K,I,J-1)-4.0*PHI1(K,I,J))/(DX*DX)      0.148s    0.05%
2572                                        PXXP=PXXK-PXXN    0.092s    0.03%
2573
2574                                        IF(K.EQ.1) THEN    0.430s    0.13%
2575                                            CK = CS(I,J)
2576                                            FK = FS(CK)    0.080s    0.02%            Divisions
2577                                            DFK = DFS(CK)    0.034s    0.01%            Divisions
2578                                        ELSEIF(K.EQ.NPP) THEN
2579                                            CK = CL(I,J)    0.038s    0.01%
2580                                            FK = FL(CK)    0.209s    0.06%            Divisions
2581                                            DFK = DFL(CK)    0.130s    0.04%            Divisions
2582                                        ELSEIF(K.GE.NPPK.AND.K.LT.NPP) THEN
2583                                            CK = CI(I,J)    0.164s    0.05%
2584                                            FK = FI(CK)    0.826s    0.25%            Divisions
2585                                            DFK = DFI(CK)    0.431s    0.13%            Divisions
2586                                        ELSE
2587                                            CK = CE(I,J)    0.195s    0.06%
2588                                            FK = FE(CK)    0.554s    0.17%            Divisions
2589                                            DFK = DFE(CK)    0.372s    0.11%            Divisions
2590                                        ENDIF
2591
2592                                        IF((N.EQ.NPP).OR.(K.EQ.NPP)) THEN    0.080s    0.02%
2593                                            EPS(I,J)=EPSL    0.022s    0.01%
2594                                            OME(I,J)=OMEL    0.008s    0.00%
2595                                            AM(I,J)=ML
2596                                        ELSEIF((N.EQ.1).OR.(K.EQ.1)) THEN
2597                                            EPS(I,J)=EPSS    0.008s    0.00%
2598                                            OME(I,J)=OMES    0.010s    0.00%
2599                                            AM(I,J)=MS    0.008s    0.00%
2600                                        elseif(((n.ge.2.and.n.lt.nppk).and.(k.ge.nppk.and.k.lt.npp-1)).or. &    0.350s    0.11%
2601                                        ((k.ge.2.and.k.lt.nppk).and.(n.ge.nppk.and.n.lt.npp-1))) then    0.030s    0.01%
2602                                            EPS(I,J)=EPSK    0.172s    0.05%
2603                                            OME(I,J)=OMEK    0.242s    0.07%
2604                                            AM(I,J)=MS    0.186s    0.06%
2605                                        elseif(((n.ge.2.and.n.lt.nppk).and.(k.ge.nppk.and.k.lt.npp-1)).or. &    0.060s    0.02%
2606                                        ((k.ge.2.and.k.lt.nppk).and.(n.ge.nppk.and.n.lt.npp-1))) then    0.010s    0.00%
2607                                            EPS(I,J)=EPSK
2608                                            OME(I,J)=OMEK
2609                                            AM(I,J)=MS
2610                                        elseif((n.ge.2.and.n.lt.nppk).or.(k.ge.2.and.k.lt.nppk)) then    0.012s    0.00%
2611                                            EPS(I,J)=EPSK
2612                                            OME(I,J)=OMEK
2613                                            AM(I,J)=MS
2614                                        ELSE
2615                                            EPS(I,J)=EPSGB    0.199s    0.06%
2616                                            OME(I,J)=OMEGB    0.028s    0.01%
2617                                            AM(I,J)=MS    0.030s    0.01%
2618                                        ENDIF
2619
2620                                        PKK=0.0    0.028s    0.01%
2621                                        DO KK=1, NPP    0.016s    0.00%
2622                                            IF(KK.NE.N.AND.KK.NE.K.AND.MSN(KK).EQ.1.AND.KK.NE.NPP) THEN    14.918s    4.59%    163.803s    32.90%
2623                                                PXXKK=(PHI1(KK,I+1,J)+PHI1(KK,I-1,J)+PHI1(KK,I,J+1) &    19.070s    5.87%            Divisions
2624                                                +PHI1(KK,I,J-1)-4.*PHI1(KK,I,J))/(DX*DX)      ! Laplacian phi    11.133s    3.42%
2625                                                IF(N.EQ.NPP) THEN    0.737s    0.23%
2626                                                    OME_NKK=OMEL    0.266s    0.08%
2627                                                    EPS_NKK=EPSL    0.472s    0.15%
2628                                                ELSEIF(N.EQ.1) THEN
2629                                                    OME_NKK=OMES    0.430s    0.13%
2630                                                    EPS_NKK=EPSS    0.250s    0.08%
2631                                                ELSEIF(N.EQ.NPP-1) THEN
2632                                                    OME_NKK=OMEGB    34.930s    10.74%
2633                                                    EPS_NKK=EPSGB    4.891s    1.50%
2634                                                ELSEIF(N.GE.NPPK.AND.N.LT.NPP-1) THEN
2635                                                    OME_NKK=OMEGB
2636                                                    EPS_NKK=EPSGB
2637                                                ELSE
2638                                                    OME_NKK=OMEGB
2639                                                    EPS_NKK=EPSGB
2640                                                ENDIF
2641
2642                                                IF(K.EQ.NPP) THEN    0.865s    0.27%
2643                                                    OME_KKK=OMEL    0.036s    0.01%
2644                                                    EPS_KKK=EPSL    0.908s    0.28%
2645                                                ELSEIF(K.EQ.1) THEN
2646                                                    OME_KKK=OMES    0.008s    0.00%
2647                                                    EPS_KKK=EPSS    0.448s    0.14%
2648                                                ELSEIF(K.EQ.NPP-1) THEN
2649                                                    OME_KKK=OMEGB    1.208s    0.37%
2650                                                    EPS_KKK=EPSGB    39.524s    12.16%
2651                                                ELSEIF(K.GE.NPPK.AND.K.LT.NPP-1) THEN
2652                                                    OME_KKK=OMEGB
2653                                                    EPS_KKK=EPSGB
2654                                                ELSE
2655                                                    OME_KKK=OMEGB
2656                                                    EPS_KKK=EPSGB
2657                                                ENDIF
2658
2659                                                PKK=PKK+0.5*(EPS_NKK**2.-EPS_KKK**2.)*PXXKK &    7.826s    2.41%
2660                                                +(OME_NKK-OME_KKK)*PHI1(KK,I,J)    4.963s    1.53%
2661                                            ENDIF
2662                                        ENDDO    21.098s    6.49%
2663
2664                                        PA(I,J)=0.5*(EPS(I,J)**2.0)*PXXP                       ! Epsilon term    0.240s    0.07%
2665                                        PB(I,J)=OME(I,J)*(PHI1(K,I,J)-PHI1(N,I,J))             ! Omega term    0.482s    0.15%
2666
2667                                        PH=1.0
2668                                        PC=PH*(FN-FK-(CN-CK)*DFK)                              ! Free energy term    0.414s    0.13%
2669
2670                                        PDX=(8.0*(PSI(I+1,J)-PSI(I-1,J))-(PSI(I+2,J)-PSI(I-2,J)))/(12.*DX)
2671                                        PDY=(8.0*(PSI(I,J+1)-PSI(I,J-1))-(PSI(I,J+2)-PSI(I,J-2)))/(12.*DX)
2672
2673                                        !PD=sigmac(i,j)*sqrt(PDX**2.+PDY**2.)/freq
2674                                        PD=sqrt((SSSI(I,J)*PDX)**2.+(SSSJ(I,J)*PDY)**2.)/freq*EPTIME*0.0
2675
2676                                        ! PTOT=PTOT-AM*DT*(PA+PB+PC+PD+PKK)                      ! Summation value
2677
2678                                        PTOT(I,J)=PTOT(I,J)-AM(I,J)*DT*(PA(I,J)+PB(I,J)+PC+PD+PKK)               ! summation value    1.736s    0.53%
2679
2680                                    ENDIF
2681                                ENDDO    0.706s    0.22%
2682
2683                                PHI2(N,I,J)=PHI1(N,I,J)+(2.0/NOP)*PTOT(I,J)   ! phi value at the next time step    0.092s    0.03%            Divisions; Type Conversions
2684
2685                                IF(PHI2(N,I,J).GT.1.0) THEN    0.019s    0.01%
2686                                    PHI2(N,I,J)=1.0
2687                                    ICK=1
2688                                    EXIT
2689                                ELSEIF(PHI2(N,I,J).LT.0.0) THEN
2690                                    PHI2(N,I,J)=0.0
2691                                    ICK=2
2692                                    EXIT
2693                                ENDIF
2694
2695                                !********** CHECKING FOR NaN  ***********
2696
2697                                !IF (ieee_is_nan(C1(I,J)) THEN
2698                                result1=(PHI2(N,I,J))
2699                                IF (ISNAN(result1))THEN    0.050s    0.02%
2700                                    WRITE(*,*)'********** NaN value in PHI PDE!! ************'
2701                                    WRITE(*,*) '# of coexisting phases at this point is:',NOP
2702                                    WRITE(*,*) 'I,J,N,NNN,PHI2(N,I,J)'
2703                                    WRITE(*,*) I,J,N,NNN,result1
2704                                    WRITE(*,*)
2705                                    WRITE(*,*) 'CS(I,J),CI(I,J),CE(I,J),CL(I,J)'
2706                                    WRITE(*,*) CS(I,J),CI(I,J),CE(I,J),CL(I,J)
2707                                    WRITE(*,*)
2708                                    WRITE(*,*) 'PB contents: PHI1(K,I,J),PHI1(N,I,J)'
2709                                    WRITE(*,"(4F12.2)") PHI1(K,I,J),PHI1(N,I,J)
2710                                    WRITE(*,*)
2711                                    WRITE(*,*) 'CL(I,J),FL(CK),DFL(CK)'
2712                                    WRITE(*,*) CL(I,J),FL(CK),DFL(CK)
2713                                    WRITE(*,*)
2714                                    WRITE(*,*) 'CS(I,J),FS(CK),DFS(CK)'
2715                                    WRITE(*,*) CS(I,J),FS(CK),DFS(CK)
2716                                    WRITE(*,*)
2717                                    WRITE(*,*) 'CI(I,J),FI(CK),DFI(CK)'
2718                                    WRITE(*,*) CI(I,J),FI(CK),DFI(CK)
2719                                    WRITE(*,*) '********** NaN value in Field equation! ************'
2720                                    pause
2721
2722                                ENDIF
2723
2724                            ENDIF
2725
2726                        ENDDO    0.048s    0.01%
2727
2729                        IF(ICK.EQ.1) THEN
2730                            DO K=1,NPP    0.020s    0.01%    0.008s    0.00%
2731                                IF(K.NE.N) PHI2(K,I,J)=0.0
2732                            END DO
2733                        ELSEIF(ICK.EQ.2) THEN    ! recalculate phi2 after phi2(N,I,J)=0 and msn(N)=0 (hopefully assuming phi1(N,I,J)=0)
2734                            MSN(N)=0
2735                            IF(NOP.EQ.2) THEN    0.008s    0.00%
2736                                DO K=1,NPP            0.012s    0.00%
2737                                    IF(MSN(K).EQ.1) PHI2(K,I,J)=1.0    0.012s    0.00%
2738                                END DO
2739                            ELSEIF(NOP.GT.2) THEN
2740                                NOP=NOP-1
2741                                GOTO 108
2742                            ENDIF
2743                        ENDIF
2744
2745                        !*****
2749                        PSUM1=0.0    0.012s    0.00%            Unpacks
2750                        DO N=1,NPP            0.012s    0.00%
2751                            PSUM1=PSUM1+PHI2(N,I,J)    0.012s    0.00%
2752                        END DO
2753                        IF(PSUM1.NE.1.0) THEN
2754                            DEL_PSUM1=1.0-PSUM1
2755
2756                            psum22=0.0
2757                            do n=1,npp            0.034s    0.01%
2758                                if(msn(n).eq.1) then    0.018s    0.01%
2759                                    psum22=psum22+0.5-dabs(phi2(n,i,j)-0.5)    0.016s    0.00%
2760                                endif
2761                            enddo
2762                            DO N=1, NPP
2763                                IF(MSN(N).EQ.1) THEN    0.012s    0.00%    0.048s    0.01%
2764                                    PHI2(N,I,J)=PHI2(N,I,J)+DEL_PSUM1  &    0.024s    0.01%
2765                                    *(0.5-dabs(phi2(n,i,j)-0.5))/(psum22) !!/DFLOAT(NOP) !!*PHI2(N,I,J)/PSUM1  !!!    0.012s    0.00%            Divisions
2766                                ENDIF
2767                            END DO
2768                        ENDIF
2769
2770                    ENDIF
2771
2773                    ! PHI_i
2774                    P11  = PHI05I(1,I,J)    !H(PHI05I(1,I,J))       ! (I+1/2,J)    0.042s    0.01%
2775                    P12  = PHI05I(1,I-1,J)  !H(PHI05I(1,I-1,J))     ! (I-1/2,J)    0.030s    0.01%
2776                    P13  = PHI05J(1,I,J)    !H(PHI05J(1,I,J))       ! (I,J+1/2)
2777                    P14  = PHI05J(1,I,J-1)  !H(PHI05J(1,I,J-1))     ! (I,J-1/2)
2778
2779                    P41  = PHI05I(4,I,J)    !H(PHI05I(4,I,J))       ! (I+1/2,J)
2780                    P42  = PHI05I(4,I-1,J)  !H(PHI05I(4,I-1,J))     ! (I-1/2,J)
2781                    P43  = PHI05J(4,I,J)    !H(PHI05J(4,I,J))       ! (I,J+1/2)    0.008s    0.00%
2782                    P44  = PHI05J(4,I,J-1)  !H(PHI05J(4,I,J-1))     ! (I,J-1/2)
2783
2784                    P21  = PHI05I(2,I,J)    !H(PHI05I(2,I,J))       ! (I+1/2,J)    0.008s    0.00%
2785                    P22  = PHI05I(2,I-1,J)  !H(PHI05I(2,I-1,J))     ! (I-1/2,J)    0.008s    0.00%
2786                    P23  = PHI05J(2,I,J)    !H(PHI05J(2,I,J))       ! (I,J+1/2)
2787                    P24  = PHI05J(2,I,J-1)  !H(PHI05J(2,I,J-1))     ! (I,J-1/2)
2788
2789                    P31  = PHI05I(3,I,J)    !H(PHI05I(3,I,J))       ! (I+1/2,J)    0.012s    0.00%
2790                    P32  = PHI05I(3,I-1,J)  !H(PHI05I(3,I-1,J))     ! (I-1/2,J)
2791                    P33  = PHI05J(3,I,J)    !H(PHI05J(3,I,J))       ! (I,J+1/2)
2792                    P34  = PHI05J(3,I,J-1)  !H(PHI05J(3,I,J-1))     ! (I,J-1/2)    0.008s    0.00%
2793
2794                    !! dC_i
2795                    C11 = CS(I+1,J)-CS(I,J);
2796                    C12 = CS(I,J)-CS(I-1,J);
2797                    C13 = CS(I,J+1)-CS(I,J);
2798                    C14 = CS(I,J)-CS(I,J-1);
2799
2800                    C41 = CE(I+1,J)-CE(I,J);
2801                    C42 = CE(I,J)-CE(I-1,J);
2802                    C43 = CE(I,J+1)-CE(I,J);
2803                    C44 = CE(I,J)-CE(I,J-1);
2804
2805                    C21 = CI(I+1,J)-CI(I,J);
2806                    C22 = CI(I,J)-CI(I-1,J)    0.012s    0.00%
2807                    C23 = CI(I,J+1)-CI(I,J);
2808                    C24 = CI(I,J)-CI(I,J-1)
2809
2810                    C31 = CL(I+1,J)-CL(I,J);
2811                    C32 = CL(I,J)-CL(I-1,J)
2812                    C33 = CL(I,J+1)-CL(I,J);
2813                    C34 = CL(I,J)-CL(I,J-1)
2814
2815                    CS11 = CS05I(I,J); CS12 = CS05I(I-1,J)
2816                    CS13 = CS05J(I,J); CS14 = CS05J(I,J-1)
2817
2818                    CE41 = CE05I(I,J); CE42 = CE05I(I-1,J)
2819                    CE43 = CE05J(I,J); CE44 = CE05J(I,J-1)
2820
2821                    CI21 = CI05I(I,J); CI22 = CI05I(I-1,J)
2822                    CI23 = CI05J(I,J); CI24 = CI05J(I,J-1)
2823
2824                    CL31 = CL05I(I,J); CL32 = CL05I(I-1,J)
2825                    CL33 = CL05J(I,J); CL34 = CL05J(I,J-1)
2826
2827                    ! PHI_i*C_i
2828                    PHIC051=P11*CS11+P21*CI21+P31*CL31+P41*CE41
2829                    PHIC052=P12*CS12+P22*CI22+P32*CL32+P42*CE42
2830                    PHIC053=P13*CS13+P23*CI23+P33*CL33+P43*CE43    0.008s    0.00%
2831                    PHIC054=P14*CS14+P24*CI24+P34*CL34+P44*CE44    0.028s    0.01%
2832
2833                    ! dPSI
2834                    PSI11 = PSI(I+1,J)-PSI(I,J);    PSI12 = PSI(I,J)-PSI(I-1,J)
2835                    PSI13 = PSI(I,J+1)-PSI(I,J);     PSI14 = PSI(I,J)-PSI(I,J-1)
2836
2837                    APK1 = DDDI(I,J)  *(P11*C11+P21*C21+P31*C31+P41*C41     &
2838                    -ZEKT(I,J)*PHIC051*PSI11)                            0.010s    0.00%
2840
2841                    APK2 = DDDI(I-1,J)*(P12*C12+P22*C22+P32*C32+P42*C42  &    0.024s    0.01%
2842                    -ZEKT(I,J)*PHIC052*PSI12)
2844
2845                    APK3 = DDDJ(I,J)  *(P13*C13+P23*C23+P33*C33+P43*C43  &
2846                    -zekt(I,J)*PHIC053*PSI13)
2848
2849                    APK4 = DDDJ(I,J-1)*(P14*C14+P24*C24+P34*C34+P44*C44  &    0.020s    0.01%
2850                    -ZEKT(I,J)*PHIC054*PSI14)
2852
2853                    C2(I,J) = C1(I,J)+DT*(APK1-APK2+APK3-APK4)/(DX*DX)    0.044s    0.01%            Divisions
2854
2855                    !! ****** CHECKING FOR STRANGE OR NaN values *****
2856                    IF(C2(I,J).GE.1.0) THEN
2857                        WRITE(*,*) 'TIME:',TIME
2858                        WRITE(*,*) 'NNN,I,J, C1(I,J),C2(I,J)'
2859                        WRITE(*,*) NNN,I,J, C1(I,J),C2(I,J), 'C2 VALUE IS STRANGE'
2860                        C2(I,J)=(C2(I+1,J)+C2(I-1,J)+C2(I,J-1)+C2(I,J+1))/4
2861
2862                        IF(PHI1(NPP,I,J).GE.0.85) C2(I,J) = 0.97
2863
2864                        !C2(I,J) = C1(I,J)
2865                        !STOP
2866
2867                    ELSEIF(C2(I,J).LE.0.0) THEN
2868                        WRITE(*,*) 'TIME:',TIME
2869                        WRITE(*,*) 'NNN,I,J, C1(I,J),C2(I,J)'
2870                        WRITE(*,*) NNN,I,J, C1(I,J),C2(I,J), 'C2 VALUE IS STRANGE'
2871                        C2(I,J)=(C2(I+1,J)+C2(I-1,J)+C2(I,J-1)+C2(I,J+1))/4
2872
2873                        IF(PHI1(NPP,I,J).GE.0.85) C2(I,J) = 0.97
2874
2875                        !C2(I,J) = C1(I,J)
2876                        !STOP
2877
2878                    ENDIF
2879
2880                    !********** CHECKING FOR NaN @ C Equation ***********
2881                    !IF (ieee_is_nan(C1(I,J)) THEN
2882                    result=(C2(I,J))
2883                    IF (ISNAN(result))THEN
2884                        WRITE(*,*) '!********** Found NaN @ C Equation *****************'
2885                        WRITE(*,*) 'TIME:',TIME
2886                        WRITE(*,*) 'I,J,NNN,result'
2887                        WRITE(*,*) I,J,NNN,result
2888                        WRITE(*,*) 'DT,DX,APK1,APK2,APK3,APK4'
2889                        WRITE(*,*) DT,DX,APK1,APK2,APK3,APK4
2890                        WRITE(*,*)
2891                        WRITE(*,*) 'DDDI(I,J),P11,C11,P21,C21,P31,C31,P41,C41'
2892                        WRITE(*,*) DDDI(I,J),P11,C11,P21,C21,P31,C31,P41,C41
2893                        WRITE(*,*)
2894                        WRITE(*,*) 'P13,C13,P23,C23,P33,C33,P43,C43'
2895                        WRITE(*,*) P13,C13,P23,C23,P33,C33,P43,C43
2896                        WRITE(*,*)
2897                        WRITE(*,*) 'P12,C12,P22,C22,P32,C32,P42,C42'
2898                        WRITE(*,*) P12,C12,P22,C22,P32,C32,P42,C42
2899                        WRITE(*,*)
2900                        WRITE(*,*) 'P14,C14,P24,C24,P34,C34,P44,C44'
2901                        WRITE(*,*) P14,C14,P24,C24,P34,C34,P44,C44
2902                        WRITE(*,*)
2903                        WRITE(*,*) 'PHIC051,PHIC052,PHIC053,PHIC054'
2904                        WRITE(*,*) PHIC051,PHIC052,PHIC053,PHIC054
2905                        WRITE(*,*)
2906                        WRITE(*,*) 'PSI11,PSI12,PSI13,PSI14'
2907                        WRITE(*,*) PSI11,PSI12,PSI13,PSI14
2908                        WRITE(*,*)
2909                        WRITE(*,*) 'PSI(I+1,J),PSI(I,J),PSI(I,J),PSI(I-1,J)'
2910                        WRITE(*,*) PSI(I+1,J),PSI(I,J),PSI(I,J),PSI(I-1,J)
2911                        WRITE(*,*)
2912                        WRITE(*,*) 'DDDI(I,J)  *(P11*C11+P21*C21+P31*C31+P41*C41'
2913                        WRITE(*,*) DDDI(I,J)  *(P11*C11+P21*C21+P31*C31+P41*C41)
2914                        WRITE(*,*) '!**************************************************'
2915
2916                        STOP
2917                    ENDIF
2918
2919                ENDDO
2920            ENDDO
TimP
You haven't shown information on effectiveness of parallelization.  You would need to separate the cases for specific values of the do loop variables and simplify the inner loops.
vahid_a_1
Dear Tim,
Thanks a lot for the point that you made. I am not sure what you mean by the "information on effectiveness of parallelization". Here, I will try to elabrate more on what I have done so far. I compiled the code using:
ifort -g -O3 -qopt-report=5 -xHOST -simd huh_electromigration.f90 (serial mode)
ifort -g -O3 -qopt-report=5 -xHOST -simd -qopenmp huh_electromigration.f90 (OpenMP mode)
The Openmp runtime is the same as the serial run-time. I observe an exponential increase in the loop run-time. To be more precise, The 1st iteration run-time is 0.45 seconds and gradually it increases up to 1.8 seconds after 50 iterations and it goes on.
In addition, the Top Down section is as below:
From the above table, I noticed that the loop in row 1828 (row 73 in the below code) seems to be the main source of issue. This is because, that loop is the very inner loop and it costs 18.110 seconds to run. When I checked the loop content, there is this N variable inside the loop which comes from the top level Do loop. Is this the reason of slow down in the code?!
How should I rewrite the code to overcome the dependency of the loops with each other?
In addition, Intel Advisor is not providing any suggestion for this part.
Here is that portion of the code again:
DO I=0, IG, 1
          DO J=0, JG, 1
108             IF(NOP(I,J).GE.2) THEN
                    ICK=0
                    DO N=1, NPP
                        IF(MSN(N,I,J).EQ.1) THEN
                            PXXN=PXXARY(N,I,J)  !(PHI1(N,I+1,J)+PHI1(N,I-1,J)+PHI1(N,I,J+1)+PHI1(N,I,J-1)-4.0*PHI1(N,I,J))/(DX*DX)
                            IF(N.EQ.1) THEN
                                CN = CS(I,J)
                                FN = FS(CN)
                                CN = CL(I,J)
                                FN = FL(CN)
                                CN = CI(I,J)
                                FN = FI(CN)
                            ELSE
                                CN = CE(I,J)
                                FN = FE(CN)
                            ENDIF
                            PTOT = 0.0
                            DO K=1, NPP
                                IF(K.NE.N.AND.MSN(K,I,J).EQ.1) THEN
                                    PXXK=PXXARY(K,I,J)   !(PHI1(K,I+1,J)+PHI1(K,I-1,J)+PHI1(K,I,J+1)+PHI1(K,I,J-1)-4.0*PHI1(K,I,J))/(DX*DX)      ! Laplacian phi
                                    PXXP=PXXK-PXXN
                                    IF(K.EQ.1) THEN
                                        CK = CS(I,J)
                                        FK = FS(CK)
                                        DFK = DFS(CK)
                                        CK = CL(I,J)
                                        FK = FL(CK)
                                        DFK = DFL(CK)
                                        CK = CI(I,J)
                                        FK = FI(CK)
                                        DFK = DFI(CK)
                                    ELSE
                                        CK = CE(I,J)
                                        FK = FE(CK)
                                        DFK = DFE(CK)
                                    ENDIF
                                        EPS(I,J)=EPSL
                                        OME(I,J)=OMEL
                                        AM(I,J)=ML
                                        EPS(I,J)=EPSS
                                        OME(I,J)=OMES
                                        AM(I,J)=MS
                                    elseif(((n.ge.2.and.n.lt.nppk).and.(k.ge.nppk.and.k.lt.npp-1)).or. ((k.ge.2.and.k.lt.nppk).and.(n.ge.nppk.and.n.lt.npp-1))) then
                                        EPS(I,J)=EPSK
                                        OME(I,J)=OMEK
                                        AM(I,J)=MS
                                        EPS(I,J)=EPSK
                                        OME(I,J)=OMEK
                                        AM(I,J)=MS
                                    ELSE
                                        EPS(I,J)=EPSGB
                                        OME(I,J)=OMEGB
                                        AM(I,J)=MS
                                    ENDIF
                                    PKK=0.0
                                    DO KK=1, NPP
                                        IF(KK.NE.N.AND.KK.NE.K.AND.MSN(KK,I,J).EQ.1.AND.KK.NE.NPP) THEN
                                            PXXKK=(PHI1(KK,I+1,J)+PHI1(KK,I-1,J)+PHI1(KK,I,J+1)+PHI1(KK,I,J-1)-4.*PHI1(KK,I,J))/(DX*DX)      ! Laplacian phi
                                            IF(N.EQ.NPP) THEN
                                                OME_NKK=OMEL
                                                EPS_NKK=EPSL
                                            ELSEIF(N.EQ.1) THEN
                                                OME_NKK=OMES
                                                EPS_NKK=EPSS
                                                OME_NKK=OMEGB
                                                EPS_NKK=EPSGB
                                                OME_NKK=OMEGB
                                                EPS_NKK=EPSGB
                                            ELSE
                                                OME_NKK=OMEGB
                                                EPS_NKK=EPSGB
                                            ENDIF
                                            IF(K.EQ.NPP) THEN
                                                OME_KKK=OMEL
                                                EPS_KKK=EPSL
                                            ELSEIF(K.EQ.1) THEN
                                                OME_KKK=OMES
                                                EPS_KKK=EPSS
                                                OME_KKK=OMEGB
                                                EPS_KKK=EPSGB
                                                OME_KKK=OMEGB
                                                EPS_KKK=EPSGB
                                            ELSE
                                                OME_KKK=OMEGB
                                                EPS_KKK=EPSGB
                                            ENDIF
                                            PKK=PKK+0.5*(EPS_NKK**2.-EPS_KKK**2.)*PXXKK + (OME_NKK-OME_KKK)*PHI1(KK,I,J)
                                        ENDIF
                                    ENDDO
                                    PH=1.0
                                    PD=sqrt((SSSI(I,J)*PDX)**2.+(SSSJ(I,J)*PDY)**2.)/freq!*EPTIME*0.0
                                ENDIF
                            ENDDO
ENDDO
ENDDO
TimP
For example, you may be able to change to DO K=2,NPP-1 by moving those 1 and NPP cases outside the loop.  Optimizing inner loops may speed up the application but may reduce parallel speedup.
Your advisor diagnostics bear mainly on vectorization of inner loops, not on parallelism.  Your opt-report would show whether the parallel do was implemented, as would testing performance with appropriate settings of OMP_NUM_THREADS and OMP_PLACES.
ifort tends not to optimize such large numbers of private variables.    I don't know whether BLOCK may be a solution.  Quotable benchmarks such as Cactus ADM were made to optimize using -Qparallel rather than using many privates.
If the parentheses are important, you will need -standard-semantics or protect_parens.
The flag comment about divisions may indicate that -no-prec-div (if set, as it is by default) has not succeeded in moving them outside the loop.
