Analyzers
5252 Discussions
Passing string longer than 32 chars - first 16 bytes get filled with 0
Rajko_T_
Consider this simple program:
#include <string>
#include <assert.h>
void foo(const std::string& str)
   assert(str[0] != 0);
int main()
   foo("Test longer than 32 characters like this");
   return 0;
If the string passed to foo() is longer than 32 characters, then the assert throws an error. Detailed inspection shows first 16 characters of 'str' to be filled with 0 (therefore the string is - unexpectedly - altered)! Any workarounds?
Ray
InspectorXE 2016 - Update 2
Visual Studio 2015 Community
Kevin_O_Intel1
What type of  Inspector analysis are you running?
It sounds like you might be running into a memory checker guard zone.
Can you try running a level 2 "Detect memory problems" analysis?
I'll run your example and see if under which conditions the issue duplicates.
Kevin
Rajko_T_
It happens only when running with "Enable debugger when problem detected" option (level 2 or 3). At Level 1 or with "Analyze without debugger", no problems are encountered.
Ray
Kevin_O_Intel1
I just tested your example using the 2017 beta version of Inspector.
I'm not seeing the issue with this version. Can you try the 2017 beta?
Kevin
