Analyzers
5282 Discussions
Problem to uninstall VTune from a Debian system
Jérôme
I installed a Non Commercial version of VTune, and I now want to uninstall it (I have some problem with VTune on my machine, I will post another thread about that).
When I try to lauch the uninstall program: /opt/intel/vtune/bin/uninstall_vtune.sh
The output is:
No products are available for uninstall.
TimP
The uninstall script presumably looks in rpmdb before continuing. Assuming that you installed in some fashion other than by use of rpm, you would select a corresponding method for removal.
Jérôme
I installed VTune using the classical method, ie. using the install.sh script. I think remember this script is based upon rpm. In the other hand, I am using Debian: rpm is not installed, there is no file called rpmdb in the system, there is no process containing rpm string.
I will uninstall by hand, but I was curious to find the reason.
