Analyzers
Problem using -gtool option on Vtune.
Adriano_G_
I need to collect data from MPI 2 applications, with dynamic process creation. The way I found is getting data for each process separately using -gtool option, but for any MPI application I get the same issue:
mpirun was unable to launch the specified application as it could not find an executable:
Executable: -gtool
Node: Scherm-Workstation
while attempting to start process rank 0.
I've tried many different command lines, but the simplest one is like:
mpirun -gtool "amplxe-cl -c advanced-hotspots -r my_dir:all=node-wide" -n 1 ./mpi N_children
Where "N_children" is the number of children processes to be created.
I'm using vtune_amplifier_xe_2016.3.0.463186 on linux.
Any suggestions about how to solve that or better ways to profile MPI 2 applications?
Thanks!
Dmitry_P_Intel1
Hello Adriano,
Starting from VTune Amplifier XE 2017 the following semantics should work regardless if you have VTune driver installed or not to collect PMU events that is needed for advanced-hotspots:
mpirun -N1 amplxe-cl -c advanced-hotspots -r my_dir ./mpi N_children
For openmpi you should add -trace-mpi option:
mpirun -N1 amplxe-cl -c advanced-hotspots -r my_dir -trace-mpi ./mpi N_children
Thanks & Regards, Dmitry
Adriano_G_
Well... I was using the normal openmpi instead of intel mpi, that was the problem.
So, I indicate the correct path (/opt/intel/compilers_and_libraries_2016.3.210/linux/mpi/intel64/bin/mpirun) and it worked well.
Dmitry_P_Intel1
Hello Adriano,
