Analyzers
5338 Discussions
Problem when importing files to result folder
Poornima_N_Intel
I'm trying to import the trace files collected using SEP tool in vtune.
I use the below command
C:\Users\pyn>amplxe-cl -import ToS_720p_29.97ps_H264_4000kbps_NOAUD_4min_R3.tb6 -result-dir=C:\SepDataCollectio\nodiSwamyProject\TOS_1C1T_720p304
I get the Below error:
amplxe: Error: 0x40000007 (Not found) -- C:\SepDataCollectio\nodiSwamyProject\TOS_1C1T_720p304
Anyone know the solution to resolve?
Peter_W_Intel
If the .tb6 file was not corrupted (you can collect it again), the problem could be file/directory write-permission issue, I guess.
1. Can you generate result under C:\Users\pyn?
2. Can you use amplxe-gui to import? Usually it generate result under your user directory, I think.
