Analyzers
5274 Discussions
Problem with finalizing results on vtune amplifier XE
Anonymous17
I am using Vtune amplifier XE trail version on Ubuntu 14.04 64-bit OS. I am trying to profile an application. The problem is that "hot spot" analysis successfully finalize the results, whereas, when I try to perform the concurrency and 'lock and wait' analysis, It gets stuck when finalizing the results during trace file (the progress bar does not move). It shows in both the cases ( concurrency & lock and wait) that the analysis is successfully completed.
Thanking you in advance.
