Analyzers
5342 Discussions
Profiling Apache using VTune
rohamsameni
I tried to create a call graph of apache server using vtune, but the graph does not match the execution path I traced using "gdb". Basically it misses some of the function calls after main(). My assumption is that maybe it has something to do with the multi-threading architecture of Apache. Anyone has an idea what's the reason behind it? How can I fix it?
Peter_W_Intel
Did you talk about VTune Amplifier XE 2011 XE? Or old product VTune Performance Analyzer?
VTune AmplifierXE captures samples with statistical call stack info. It meansifthe callee ran shortly - so there is no sample captured, and no caller info recorded. (In other word, VTune Amplifier XE provides call graphinfo - onlybut only callees are hot functions)
VTune Performance Analyzer's call graph will do FULL instrumentation of your binaries, so function call will not be missed.
Regards, Peter
