Analyzers
5342 Discussions
Profiling OpenMP program with vtune command line
Bo_F_
Hi all,
I understand that vtune supports openmp programs. But from the documents I read, I only see GUI based versions. I am wondering if I can use command line vtune on linux to get the similar reports (like showing how much time spent in openmp region xxx).
I tried it , the report I got was like this:
amplxe: Using result path `/home/lud/omp/lud_duplication/random_0.04_keep/r002ah'
amplxe: Executing actions 50 % Generating a report                             Function                  Module       CPU Time  Spin Time:Imbalance or Serial Spinning (OpenMP)  Spin Time:Lock Contention (OpenMP)  Spin Time:Communication (MPI)  Spin Time:Other  Overhead Time:Creation (OpenMP)  Overhead Time:Scheduling (OpenMP)  Overhead Time:Reduction (OpenMP)  Overhead Time:Other
func@0x402280             lud_omp.exe    0.054s                                               0s                                  0s                             0s               0s                               0s                                 0s                                0s                   0s
func@0x40162d             lud_omp.exe    0.032s                                               0s                                  0s                             0s               0s                               0s                                 0s                                0s                   0s
func@0x401840             lud_omp.exe    0.032s                                               0s                                  0s                             0s               0s                               0s                                 0s                                0s                   0s
func@0x402730             lud_omp.exe    0.010s                                               0s                                  0s                             0s               0s                               0s                                 0s                                0s                   0s
[vmlinux]                 vmlinux        0.003s                                               0s                                  0s                             0s               0s                               0s                                 0s                                0s                   0s
__kmp_dispatch_init<int>  libiomp5.so    0.001s                                               0s                                  0s                             0s               0s                               0s                             0.001s                                0s                   0s
put_rpccred               sunrpc.ko      0.001s                                               0s                                  0s                             0s               0s                               0s                                 0s                                0s                   0s
But I have no way to figure out which func maps to which openmp region, or should they match?
Thanks!
Bo
