Analyzers
5270 Discussions
Program running with 2 threads although OMP_NUM_THREADS=1
schorscherl
Hi all,
when I run my OpenMP program using the cli version
of VTune 3.0b, it runs with one thread when I set OMP_NUM_THREADS=1,
as expected (this is for callgraph profiling). When I do the same
under GUI (vtlec) control, it insists on running with 2 threads. I
have tried setting OMP_NUM_THREADS=1 on the command line before
starting vtlec, as well as setting it in the 'Advanced' project
options (user-defined environment), but this does not help. OMP_NUM_THREADS
seems to get ignored when the GUI is running.
Any ideas?
Georg.
PS: This is on a dual Xeon, SuSE 8.1, Kernel 2.4.24.
TimP
Sometimes, it has been necessary to run a script, in which the environment variables are set before starting the application.
OpenMP programs built with Intel compilers have 2 monitor threads, in addition to those counted under OMP_NUM_THREADS. Intel libguide and linux libpthread each are responsible for one. They normally accumulate well under a second together. I'm not certain from your description whether those are involved.
schorscherl
I can see the two helper threads, but there is one additional thread
which collects a lot of CPU time, and it is definitely a compute
thread. Besides, the program uses omp_get_num_threads() to determine
the number of threads it is running on, and this number is reported
as 2.
The script trick works, ok.
Btw, I have checked that the problem does not appear when doing
IP sampling. Strange.
Georg.
