Analyzers
5341 Discussions
Re: VTune Profiler cannot recognize the processor
bariserkus
In my case, the problem was due to the fact that newer versions of Vtune does not support the older versions of Intel processors. So, in my case, I cannot use the newer versions of Vtune on my PCs.
Thanks for the response.
AlekhyaV_Intel
Thank you for posting in Intel Communities. We are sorry that you're not able to use VTune on your PC due to an older processor. We have a workaround for you. You could register to oneAPI DevCloud and use VTune profiler hassle-free.
Please follow below steps to enroll:
  1. Click on Enroll on top right corner in this page: https://devcloud.intel.com/oneapi/
  2. Connect to DevCloud via SSH by following all the steps from this documentation: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
  3. Once are logged into DevCloud, you could use Intel VTune from the path -> /opt/intel/oneapi/vtune/latest
If this helps in resolving your issue, make sure to accept this as solution. This helps others with similar error. Thank you!
Alekhya
AlekhyaV_Intel
We have not heard back from you. Has the solution provided helped? Please give us an update regarding this issue.
Alekhya
AlekhyaV_Intel
We assume that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
