Analyzers
Result path not found
Weiss__Christian
I want to create a hotspot report according to the help information
1) Generate the 'hotspots' report for the result directory 'r000hs'.
    amplxe-cl -report hotspots -r r000hs
However, I always get the error message
amplxe: Error: Result path `/<basename>/r000hs' does not exist
This does not change if I create the directory /<basename>/r000hs via mkdir beforehand.
Kirill_U_Intel
Hi Christian.
what is the path where you run 'amplxe-cl ...' cmd?
could you try to use full path? something like 'amplxe-cl -report hotspots -r /tmp/r000hs'
Is it fail too?
Kirill
Emma9997
After using the absolute path, the error still appears.
The product version number is 19.
