Analyzers
5295 Discussions
Running analysis on arbitrary target (not connected)
Walas__Piotr
I'm trying to run an analysis on Linux target which is not accessible from my host (Windows) w/ V-Tune installed. Following the manual <link> I've took from installation directory vtune_amplifier_target_x86_64.tgz and unpacked on the target. Then, I generated the command line in V-Tune no my host (WHERE set to Arbitrary Host):
amplxe-cl -collect uarch-exploration -knob collect-memory-bandwidth=true --duration 10
The problem is that amplxe-cl is not present in above target package. How can I run analysis without installing V-Tune on the target?
Thanks in advance,
Piotr
