Analyzers
5307 Discussions
SSA not generating results file
Raj_J_
I am trying to run the SSA (2013) on a project of ours  in VS 2010. When I build for static analysis the build completes but I do not get a results file. I do have some link warnings (see below):
1>message.obj : warning LNK4221: This object file does not define any previously undefined public symbols, so it will not be used by any link operation that consumes this library
1>library.obj : warning LNK4221: This object file does not define any previously undefined public symbols, so it will not be used by any link operation that consumes this library
Are these warnings preventing the static analysis from running? Is there something I can do about this?
Raj
Raj_J_
My linker warnings were a red herring (one of many I ran into).
Turns out that in order for SSA to properly run and generate results you need to have the Interprocedural Optimization (/q[no]ipo) option set to Yes.
Raj
Peter_W_Intel
"/Qipo" option should be used if you run SSA on multiple source files, SSA will check with cross files then generate result.
