Analyzers
5340 Discussions
Sampling API Error: resume sampling collection failed.
slohn
currently I am struggeling with the error as mentioned above.
One of our programmers made the effort to include performance analysis into our framework to perform a hotspotanalysis (VTune Amplifier XE Upd. 8), what is working quite nicely. But when I change the hotspotanalysis to a user defined hw event counting like this:
$AMPLXECMD -collect-with runsa -knob event-config="$HWEVENTS" -start-paused -follow-child \\
-target-duration-type=medium -no-allow-multiple-runs -no-analyze-system \\
-data-limit=500 -slow-frames-threshold=40 -fast-frames-threshold=100 \\
-r=$OUTPUTDIR/r@@@ -- $APPLICATION
Then I recieve the error message. Reducing the command did not show any improvements. The ide is to profile specific algorithms that appear in VTune then as tasks. If an algorithm is started there is a before hook asking for some customized code, where we put:
taskId = __itt_event_create(typeName.c_str(), typeName.size());
__itt_event_start(state.event);
and if started:
__itt_event_end(state.parent_event);
just before the start and so on. Between algorithms the profiling is paused and then resumed. Means it will be called with high frequency. Is this a problem? How could I fix it?
After browsing through the web, I did not found any solution. Has somebody any idea?
Stefan
Peter_W_Intel
I don't know why did you use pause mode, did you resume sampling in code?
Secondary, event start/end is only marked in timeline report. And it's for user-mode sampling (Hotspots, Concurrency Analysis, LocksAndWaits Analysis), NOT for PMU event-based sampling.
Here I gave you a simple example - matrix1.c
[cpp]#include #include #include #include "ittnotify.h" #define NUM 512 double a[NUM][NUM], b[NUM][NUM], c[NUM][NUM]; __itt_event event_matrix; void multiply() { unsigned int i,j,k; __itt_event_start(event_matrix); for(i=0;i = 0.0; for(k=0;k += a*b; } } } __itt_event_end(event_matrix); } main() { clock_t start, stop; event_matrix = __itt_event_create ("Mark matrix event", 17); //start timing the matrix multiply code start = clock(); multiply(); stop = clock(); // print elapsed time printf("Elapsed time = %lf secondsn", ((double)(stop - start)) / CLOCKS_PER_SEC); } [/cpp]
gcc -g matrix1.c -I/opt/intel/vtune_amplifier_xe_2011/include /opt/intel/vtune_amplifier_xe_2011/lib64/libittnotify.a -lpthread -ldl -o matrix1
# amplxe-cl -collect hotspots -- ./matrix1
Elapsed time = 0.740000 seconds
Using result path `/home/peter/problem_report/r001hs'
Executing actions 75 % Generating a report
Summary
Elapsed Time: 0.761
CPU Time: 0.750
Executing actions 100 % done
Open result from amplxe-gui, note "User Task" mark in timeline report
slohn
I think this clarifies why it is not running.
The only point is, that using tasks gives me another possibility to group processing time, right? But if I use frames, I can do the same and user event sampling is covered as well, isn't it? So where is the difference between events and frames?
Stefan
Peter_W_Intel
Using __itt_frame is another approach when you do same (similar) works in a loop, so all performance dataare classifiedin eachiteration, please see this article.
__itt_event provides APIstomark"event star/end"in timeline report, whereyou runcritical code. Usually use "zoom-in/filter on selection", tofocus on this time range to review result.
Regards, Peter
