Analyzers
5281 Discussions
Sampling with Remote Machine and problems with the exrta files
bijilash_babu
This should be noticed!!!
If you sample using a remote Windows machine and then want
to sample locally, the next button in the cofig wizard may not
be active. If so just remove all the "extra files" which were created
in the same folder during remote sampling.
I think Intel should mention this in the documents :)
-Bijilash
David_A_Intel1
Thanks, Bigilash. I'm not sure exactly what you mean, though. Can you describe the problem more completely?
bijilash_babu
Hi DaveA,
Sorry for being not very clear, actually I have been trying to
optimize a code which is to be run on a Linux Machine. I decided to
do remote sampling from a Windows machine using VTune. When I tried
to sample again from the same linux machine some of the buttons(next)
did not work. ie. you can't proceed after a stage. When I removed all
the extra files which were created bye the Windows session (which were
there in the same folder as that of the executable),"everything started
working normally"
I thought its better to post this, so that no one will face this again :)
Cheers,
Bijilash
David_A_Intel1
So, let me see if I understand...
You collected sampling data on a Linux* system from a Windows* system via the remote data collector. Then, you went to the Linux system and attempted to run the 3.0 product there and could not create a sampling activity with the wizard. Is that correct?
bijilash_babu
yeaah!! exactly.
David_A_Intel1
At what point is the "Next" disabled? Is "Finish" enabled? Are you specifying an app to launch or checking the box for no app to launch?
