Analyzers
5250 Discussions
Segmentation fault while trying to generate a report
oleg_iegorov
I run
$ /opt/intel/vtune_amplifier_xe/bin64/amplxe-cl -report sfdump -result-dir .
and for some results I get the following error:
Intel VTune Amplifier XE 2011 (build 206420) feedback tool
Copyright (C) 2009-2011 Intel Corporation. All rights reserved.
Intel VTune Amplifier XE 2011 Update 7 experienced an unexpected error.
Please send a problem report:
amplxe-feedback --send-crash-report "/tmp/amplxe-log-oiegorov/2012-03-26-Mon-10-15-28-822397/crash_info.txt"
Report data may be used to improve product stability. Our apologies for the inconvenience and thank you for your assistance.
Exception: 0xb, Segmentation fault
Module: libamplxe_dicer_python_2_4.so
Collecting system information...
Collecting modules information...
The point is that for some results sfdump report is generated without problems, and I guess that the size of collected data is not the reason, as it works for some results with much larger size of collected data.
Any ideas?
Mark_D_Intel
You could try the 'hw-events' report instead.
Mark
oleg_iegorov
Yes, but sfdump gives exactly what I need - the overall number of events. Using hw-events is inconvenient in this case as it gives these values per function.
hw-events however works fine.
Mark_D_Intel
The '-group-by' option can change the granularity of the output. The list of available options can be listed with '-help report hw-events'. Try '-group-by process' (not the summary that you want, but closer).
