Analyzers
5285 Discussions
Silent Install insists on GUI components
Allard__Sebastian
I'm trying to install the CLI-component of Intel Advisor 2020 Update 1 in a Docker container based on Ubuntu 18.04 with the following command:
./install.sh --silent --accept_eula --install_dir /opt/intel/advisor_2020 --components intel-advisor-2020-cli-common__noarch
However, the installation fails and refers to missing libraries required for the GUI components. What is wrong? Do I have to install the packages anyway?
Here is the entire output:
dpkg-query: no packages found matching libgtk2.*common
dpkg-query: no packages found matching libpango-1*
cat: /proc/asound/version: No such file or directory
dpkg-query: no packages found matching libasound2*
dpkg-query: no packages found matching xserver-xorg
There are one or more critical unresolved issues which prevent setup from
continuing.  Fix them and run the setup program again.
Missing critical prerequisite
-- GTK2 library is not found. 'Graphical user interface' component(s) cannot be
installed.
The install program cannot detect a GTK2 library on the system. The graphical
user interface of the product requires GTK2 version 2.4 or higher.
To install GTK2 library, execute one of the following commands specific to your
operating system:
- Ubuntu / Debian:
sudo apt-get install libgtk2.0
- Red Hat Enterprise Linux / CentOS:
sudo yum install gtk2
- Fedora:
sudo dnf install gtk2
- SUSE Linux Enterprise Server:
sudo zypper install gtk2
Otherwise, go back and unselect 'Graphical user interface' component(s).
-- Pango library is not found. 'Graphical user interface' component(s) cannot be
installed.
The install program cannot detect the system pango library required by the
graphical user interface of the product.
To install pango library, execute one of the following commands specific to your
operating system:
- Ubuntu / Debian:
sudo apt-get install libpango-1.0-0
sudo yum install pango
- Fedora:
sudo dnf install pango
sudo zypper install pango
-- ALSA library is not found. 'Graphical user interface' component(s) cannot be
installed.
The install program cannot detect the Advanced Linux Sound Architecture system
library (libasound) required by the graphical user interface of the product.
To install ALSA library, execute one of the following commands specific to your
operating system:
- Ubuntu / Debian:
sudo apt-get install libasound2
sudo yum install alsa-lib
- Fedora:
sudo dnf install alsa-lib
sudo zypper install libasound2
- Clear Linux:
sudo swupd bundle-add devpkg-alsa-lib
-- Xorg X11 server is not found. 'Graphical user interface' component(s) cannot
be installed.
The install program cannot detect the Xorg X11 server required by the graphical
user interface of the product. Contact your system administrator to install the
package for the  architecture or install the product on a compliant system.
Sebastian
Allard__Sebastian
Well, I got it working now somehow. Might have been that cpio was missing or some spelling error.
