Analyzers
5254 Discussions
Source Search should point to post-CPP files, yes?
Ronald_G_2
Pretty obvious question/answer but thought I'd ask anyhow.
The Source Search path - my application pre-processes source files but puts the processed .c and .cxx files in a completely different path and directory tree from the source .C and .CXX files.  I am sure the Source Search path should be to the post-CPP files, to the .c and .cxx files correct?  It's a stupid and obvious question, but thought I'd be 100% sure on the answer.
Ron
TimP
VTune source search needs to find the source files which were actually passed to Intel C++.  If you are using other tools to pre-process, VTune will be able to use the debug symbol tables only to refer back to the source actually seen by the compiler.
