Analyzers
5308 Discussions
Total time vs. file duration
linadaud
I ran a profiling of a .mp4 file with the information below:
Initial Object Descriptor ID 1
Duration 00:00:15
Service Handler: GPAC IsoMedia Reader
Service URL: C:\\Documents and Settings\\daud\\Bureau\\gpac\\test_sequences\\kangaroo.mp4
Scene Description: Width 400 - Height 300
Scene Codec GPAC BIFS Decoder
However, in the call graph, I observed a total time of 9 677 035 s (in Windows via MS Visual Studio) and 10 069 015 s (in Ubuntu Linux) the main function!
Could someone explain how can this be possible? How can I observe a total time that is faster than the file duration itself?
Lina
Peter_W_Intel
Hi Lina,
I think that Call graph will spend more time than application itself, since Call graph will call functions in itslibraries.
You said that total time was from main function only, I suppose that is not enough! You have to count spending timefrom other threads.
See example for application vtunedemo on Linux*:
1. Run "time ./vtunedemo"
real 0m0.287s (real execution time)
user 0m0.812s (user's time consumed in eight cores of my system,was partialllyparallelized)
sys 0m0.002s
2. Run Call graph for vtunedemo, total time -
__libc_start_main (thread_0): 4,937,232 s
main_thread (thread_1) : 1,226,465 s
main_thread (thread_2) : 1,027,404 s
main_thread (thread_3) : 1,037,240 s
Therefore, total time = 8,228,341 s = 8.22s. It seems there are big overheads - but I have to deduct total wait time from four threads. They are
__libc_start_main (thread_0): 4,936,834 s
main_thread (thread_1) : 749,068 s
main_thread (thread_2) :746,968 s
main_thread (thread_3) : 761,892 s
Total wait time = 7,194,762 s.
Total no-wait time = 8,228,341 us - 7,194,762 s = 1,033,579 s = 1.03s
So real overheads = 1.03s - 0.81s = 0.22s
Can you please verify data again on your app, such as above example?
If you still have any concern, please let me know. Or you can submit a ticket with your example program to https://premier.intel.com. Thank you.
Regards, Peter
linadaud
I think that Call graph will spend more time than application itself, since Call graph will call fun ctions in itslibraries.
I agree with you, Peter and I'm confused with the result observed from the profiling.
I had a correct result when running in multi-thread. However, the result with total time shorter than the duration time was the one in mono-thread mode. Therefore, I think that observing the main total time would be enough since it corresponds to the application total time. Am I wrong?
I'll do as you suggest in multi-thread mode :-)
Thanks, Peter.
Lina
linadaud
Peter,
I ran the application as instructed. Below are the results:
1. run time ./application
real 15.95
user 0.20
sys 0.65
2. Run Call graph for the application (still in mono-threading)
__libc_start_main = 10, 012, 504 s
main = 10,012,458 s
I observed real execution time longer than the profiled time! How could this be?
Peter_W_Intel
Quoting linadaud
Peter,
real 15.95
user 0.20
sys 0.65
main = 10,012,458 s
Ifyour application is single application, total wait time is almost "zero", main function is execuation time.
Please submit a ticket to https://premier.intel.com with you application (test case) to us for investigating ifthis is a Call graph bug.
Remindto chekcif you are using VTune Analyzer v9.1 Update 7, which is latest product.
Regards, Peter
