Analyzers
5327 Discussions
Unable to Create New Activity
David_Coggin
I am using VTune version 9.0 Build 719 with VS2008 Professional Edition, and XP 64-bit SP2. After initially reinstalling it today after not using it for a while, it worked fine. However, since then, after closing and reopening Visual Studio, I cannot get it to run. After opening a solution in Visual Studio the Tuning Browser window is blank. Selecting Tuning - Create New Activity - and any selection (e.g. Sampling Wizard), I get an error: "An error occurred while attempting to create the selected new project wizard." I have restarted, with no luck, then uninstalled, restarted, installed, restarted, with no luck. I appreciate any help.
David
Added: I have upgraded to version 9.1 Build 385 with no change.
Next update: I uninstalled, checked for a registry entry: "HKEY_LOCAL_MACHINE\\SOFTWARE\\Intel Corporation\\VTune Performance Environment", but found none, deleted the VTune folder in Program Files, and reinstalled again-- no change.
Peter_W_Intel
In my experience -
1) Make sure that VTune Analyzer standalone app is workable, first
2) Delete "vtune" sub-directory under old solution/project directory. When you work in VS2008, will create anew "VTune" tab, and new activities...
Regards, Peter
Peter_W_Intel
In my experience -
Regards, Peter
David_Coggin
Peter,
Thanks very much for the reply.Deleting the VTune folder in the project was all it took. I should have tried that myself already after uninstalling and reinstalling so many times. Thanks a lot.
David
