Analyzers
5248 Discussions
Unable to edit ptrace_scope to use VTune in Ubuntu
TryerGit
On compiling and building an executable, I am trying to run VTune on this for hotspot analysis. I am unable to start hotspot analysis under User Mode Sampling option due to the following error:
"Cannot start data collection because the scope of ptrace system call is limited. To enable profiling, please set /proc/sys/kernel/yama/ptrace_scope to 0. To make this change permanent, set kernel.yama.ptrace_scope to 0 in /etc/sysctl.d/10-ptrace.conf and reboot the machine."
On trying to follow this advice, I navigated to the folder in question and issued:
:/proc/sys/kernel/yama$ sudo echo 0 > ptrace_scope
bash: ptrace_scope: Permission denied
but despite sudo, permission seems to be denied.
Is there a way to get around this so that I can use VTune in Linux?
Thank you.
TryerGit
TryerGit
I figured this out following the method suggested by the accepted answer below:
https://stackoverflow.com/questions/22120711/qt-creator-ptrace-operation-not-permitted-what-is-the-permanent-solution
JyothisV_Intel
Good day to you.
We hope your issue is resolved and thanks for sharing it with the community.
The same fix is mentioned in the official user guide. Refer: https://www.intel.com/content/www/us/en/develop/documentation/vtune-help/top/troubleshooting/error-ptrace-sys-call-scope-limited.html
Since, your initial query is resolved, we will be closing this thread. If you have any new queries, kindly post a new question since this thread will no longer be monitored by Intel.
Jyothis V James
