Analyzers
5253 Discussions
Unable to profile program with clang-9 and libc++ with VTune
Marshall__Andrew
Steps to reproduce -
compile the following program:
#include <iostream>
int main() {
    std::cout << "Hello World" << std::endl;
    return 0;
with
clang++-9 hello_world.cpp --stdlib=libc++  -g -O2 -o hello_world.exe
Attempting to profile with VTune results in the following error
Source/pin/elfio/img_elf.cpp: ProcessSectionHeaders: 809: unknown section type 0x6fff4c04 for sec[124,.deplibs] in /usr/lib/x86_64-linux-gnu    /libc++.so.1
# Product Version
Intel VTune Profile 2020 Update 1
Product Build 607630
# System info:
Collection and Platform Info
    Application Command Line:    /home/andrew/projects/fuel3d/work/hello_world.exe
    Operating System:    5.3.0-53-generic NAME="Ubuntu"
VERSION="18.04.4 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04.4 LTS"
VERSION_ID="18.04"
    CPU
        Name:    Intel(R) microarchitecture code named Coffeelake
        Frequency:    3.6 GHz
        Logical CPU Count:    16
Vladimir_R_Intel
Hi Andrew,
thank you for notification. According to the error message all VTune analyses using User Mode sampling or Tracing technology are broken, we will try to fix this in the nearest time.
As a workaround I suggest to use HW based sampling analyses.
BR,
Vladimir
JananiC_Intel
Thanks for reaching out.
We tried from our side and we experienced similar issue.As Vladimir said,our engineering team will fix this issue.Meanwhile you can try hardware sampling using the below command
vtune -collect hotspots -knob sampling-mode=hw -knob sampling-interval=1 -- ./hello_world.exe
We tried the above command it is working fine.
Marshall__Andrew
Regarding hardware sampling, the documentation could do with some additional information on installing the drivers on a system with Secure-Boot enabled, as is fairly common on a modern system.
All the kernel modules need to be signed with kmodsign in order to load. Just a link to https://ubuntu.com/blog/how-to-sign-things-for-secure-boot would be helpful.
JananiC_Intel
We tried User mode sampling from our side ,now it seems to be working.Could you try that once again and let us know?
Osnat_L_Intel
Hi Marshall,
Can you please send me the binary that caused the error (libc++.so.1) ?
Even better to send a tar file with the executable and all its dependent libraries.
Osnat
AckoftOvak
I have the same issue. Here is the binary.
JananiC_Intel
Could you provide an update to Osnat Levi's query?
JananiC_Intel
We are closing the case.Please raise a new thread in case of any further issues.
Bernard
Valued Contributor I
Looks like failure to parse and process some ELF64 section.
Maybe this could have affected the mapping of counter overflow to specific code trigger.
AckoftOvak
It's SHT_LLVM_DEPENDENT_LIBRARIES section (https://llvm.org/docs/Extensions.html#sht-llvm-dependent-libraries-section-dependent-libraries). VTune should just ignore it, not crash.
