Analyzers
5288 Discussions
Unable to run vtune, Error in sampling collector - Error code - 53
kostya_y
Hi
I am trying to run lightweight-hotspots analysis on my application. The application is a windows service.
I understood that only "lightweight-hotspots" analysis can be ran as when trying to run "hotspots" I recieved "Access denied" error.
I am attaching the the process and running the tool using command line.
This is the output that is produced:
Error: Failed to create tb6 file because 0 samples were collected.
2> Error in sampling collector. Err
2> or code - 53
OS is Windows XP SP3, running off a VMWare 7
Thanks in advance.
Mark_D_Intel
Analysis types based on hardware sampling will not work inside a VM.
Mark
Roman_D_Intel
VMware Fusion 5 supports now Intel VTune Amplifier event sampling : details
