Analyzers
5323 Discussions
Using Vtune Call graph Or other activity without launching application
dalido
I am trying to run the Call Graph Profile on a running application (on XP PS), so I open the "Call Graph Configuration Wizard", I choose Windows/Linux profiling, I check "no application to launch", "Modify default..." and uncheck "Run activity when done". Then I choose my exe as a module of interest and I press the "Finish" button. This sequence of operations is happening while my application is running.
I have this messge :
"It is time to run your application" message box appears and immediately after I get the message "No module from the activity was loaded".
Is it the ritght procedure? or i have to do other thigs?
Thanx .
Dido
David_A_Intel1
Hi Dido:
Call graph does not support collecting data on an already running application. Call graph must launch the application OR you can start the application AFTER starting the call graph activity. The later is for support of call graphing DLLs (see DLL-level call graph profiling in the online help).
