Analyzers
5296 Discussions
Using vtune to watch gpu offload in graphic
Hannah_zhen
Hi, community:
Recently, I have used vtune to watch gpu offload in WIN10 like:
However, as I open result generated from ubuntu CLI, some times the task is from level zero api
sometimes is from openCL
I was wondering whether it can be controlled by myself as I want to watch the time circle about gpu offload with openCL tasks.
Is there any solution to control it? Thanks in advance.
Below is my device information :
My running environment is ubuntu22.04 with 6.2.0-36-generic and the processor is i5-1340P.
The vtune version in win10 is 2024.0.0.
Rahila_T_Intel
Thank you for posting in Intel communities.
To select a specific offload device, ONEAPI_DEVICE_SELECTOR environment variables can be used. Using it affects all the device query functions and device selectors.
To check on the availability of devices for use with SYCL on a running system, simply use the sycl-ls command, e.g.:
$ sycl-ls
[opencl:acc:0] Intel(R) FPGA Emulation Platform for OpenCL(TM), Intel(R) FPGA Emulation Device 1.2 [2022.13.3.0.16_160000]
[opencl:cpu:1] Intel(R) OpenCL, 11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz 3.0 [2022.13.3.0.16_160000]
[opencl:gpu:2] Intel(R) OpenCL HD Graphics, Intel(R) Iris(R) Xe Graphics 3.0 [31.0.101.3358]
[ext_oneapi_level_zero:gpu:0] Intel(R) Level-Zero, Intel(R) Iris(R) Xe Graphics 1.3 [1.3.23828]
[host:host:0] SYCL host platform, SYCL host device 1.2 [1.2]
ONEAPI_DEVICE_SELECTOR environment variable can be used to limit the choice of devices available when the SYCL-using application is run. Useful for limiting devices to a certain type (like GPUs or accelerators) or backends (like Level Zero or OpenCL).
The ONEAPI_DEVICE_SELECTOR syntax is shared with OpenMP and also allows sub-devices to be chosen. See https://intel.github.io/llvm-docs/EnvironmentVariables.html#oneapi-device-selector for a full description.
To know more about the environment variables that are having effect on DPC++ compiler and runtime please refer the below documents.
Hope this will help in clarifying your query.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Rahila_T_Intel
$ sycl-ls
Rahila_T_Intel
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
