Analyzers
5271 Discussions
VTune 2015 collection failed
Tang_Y_
We are trying to optimize performance using  the VTune Amplifier 2015, it always returns collection failed.
The target machine is RHEL 6.3 with Linux kernel 2.6.32
We use in the trial mode
amplxe-cl -collect hotspots -duration 10 -target-pid 13649
The following is the error output:
amplxe: Collection detached.
amplxe: Fatal error: Unknown critical error
amplxe: Collection failed.
amplxe: Internal Error
As the message is not very explicit I will appreciate any help.
Peter_W_Intel
Probably you need to check if your user account has same privilege to target process, in other words - if you have to use same user account (which launched target process) to run VTune collection. For example, if you use VTune under "root" user to monitor mysql process which was launched by "mysql" user, it will fail. The solution is to launch mysql process under "root" user.
You can test other running process, to ensure the problem was not caused by other reason, for example, write-permission for result, components are destroyed to re-install the product.
If the problem persists on, you can submit an issue to https://premier.intel.com, with test case or VTune results for investigating in depth.
