Analyzers
5320 Discussions
VTune 2016 Update 2 GUI doesn't expand across multiple monitors
Scott_S-S_
I have a desktop with 4 monitors.  Parallel XE 2016 Update 2's VTune GUI was able span across the 4 monitors. However after updating to Parallel XE 2016 Update 2 this no longer possible. The VTune GUI is restricted in size to 1 monitor which makes it very difficult to use (it's not restricted to 1 monitor if VTune is executed from within Visual Studio). Intel Advisor is also afflicted with the same issue. However Intel Inspector is not, it's GUI can span across multiple monitors.
I should add that the OS is 64bit Windows 7
Scott_S-S_
James_T_Intel
I see what's happening.  I'll file a defect report on this.
James_T_Intel
This should be fixed in Intel® VTune™ Amplifier XE 2017 Beta.
