Analyzers
VTune 2022.1.0 Assert
JoeJoe
Trying to use VTune on Linux and it is asserting:
AMPLXE_TPSSCOLLECTOR: tool:1328: g_instr_global.is_libpthread_so_loaded == 0 : g_instr_global.is_libpthread_so_loaded == 1
Assertion failed: tool:1328: g_instr_global.is_libpthread_so_loaded == 0 : g_instr_global.is_libpthread_so_loaded == 1
. Please contact the technical support. *** Aborted at 1651530860 (Unix time, try 'date -d @1651530860') ***
I'm using the following command line:
vtune -collect hotspots -result-dir r004hs -- <my executable command line>
When I run <my executable command line> as a stand alone, it is running as expected in the same console window.
vtune -version:
Intel(R) VTune(TM) Profiler 2022.1.0 (build 621966) Command Line Tool
Copyright (C) 2009-2021 Intel Corporation. All rights reserved.
Any suggestions how to resolve this?
