Analyzers
5314 Discussions
VTune Amplifier 2019 Update 5 assertion failed
Rython
[Environment]
Windows 10
Visual Studio Community 2015 Update 3 (Version 14.0.25431.01)
Intel VTune Amplifier 2019 Update 5
[Log]
Data collection is completed successfully
Aug 12 2019 10:32:47 The result file 'T:\NeoX\vsproj\u2_engine\client\VTune Amplifier Results\client\r002hs\r002hs.amplxe' is successfully created and added to the project .
Assertion failed: init:208: (new_count == cur_count) : . Please contact the technical support.
Finalization completed successfully
Aug 12 2019 10:32:53 Result is ready for analysis.
Cannot load data file `T:\NeoX\vsproj\u2_engine\client\VTune Amplifier Results\client\r002hs\data.0\23644-408.0.trace' (Data file is corrupted).
I launched VTune inside Visual Studio 2015 IDE, and it always prompted `Project source code was modified. Rebuild the project before starting data collection.` even if I had just rebuilt the whole solution under `RelWithDegInfo`. It is ok if I built solution under `Debug` or `Release`.
However, whichever configuration I chose, the process failed at data collection with an assertion failed.
Any advice or suggestions?
