Analyzers
5307 Discussions
VTune Amplifier XE 2017 (3.0.510739) on Linux no longer invoking child application
Andrew_J_1
Hello, I recently started evaluating VTune internally, and I had some good successes initially. However, I was working with the VTune "scripting" team on trying to diagnose a Python issue with VTune, and now VTune has just "given up". It is worth noting that, at the current time, the Python analysis only supports the "basic" hotspot (and Locks-n-Waits) collectors. To elaborate on my issue: whatever kind of binary is passed as follows: * amplxe-cl -c hotspots nothing is collected, and all that is reported is: * amplxe: Error: 0x40000025 (Inapplicable report) -- The report 'summary' is not applicable to the result However, I fully understand this error when nothing is collected/the process is too short-lived. The problem here is that VTune is simply not invoking/launching the child job -- the process I wish to analyse has print statements (for example), and these _do not_ appear. This is why there is no data collector, the child process isn't being launched at all. VTune did previously work on my machine before I updated my Linux kernel (I updated from 3.10.0-514.21.1.el7.x86_64 to 3.10.0-514.21.2.el7.x86_64 - the smallest of point releases!). After I noticed that VTune was broken, I even completely uninstalled/reinstalled the product, but to no avail. Other things I have tried: * advanced-hotspots _do_ work, but these are incompatible with Python analyses (so they do not relevant for the purposes of this post) * manually making sure the kernel modules are loaded using insmod-sep but these have also made no difference! I was extremely impressed with what VTune could do before it "broke", so this is extremely infuriating! Any helps/tips/suggestions/things I can try to give you all more information? Cheers, Andrew
Andrew_J_1
Attached to this reply is: * The contents of the directory "/tmp/amplxe_failures", populated by this command "export AMPLXE_LOG_DIR=/tmp/amplxe_failures/amplxe_log; export AMPLXE_LOG_LEVEL=TRACE; rm -rf /tmp/amplxe_failures/r000ah; amplxe-cl -collect hotspots -target-tmp-dir=/tmp/amplxe_failures -r /tmp/amplxe_failures/r000ah -- $(which python) test.py" * The output of amplxe-feedback -create-bug-report report.zip
Vladimir_R_Intel
Hi Andrew,
Could you please try to check the following commands?
1. amplxe-cl -c hotspots /bin/ls
2. amplxe-cl -c hotspots -mrte-mode=native <your_application_with_parameters>
3. pin -xyzzy -mesgon log_injector -mesgon log_syscall -unique_logfile -- <your_application_with_parameters>
And if the third item will fail please send me collected logs.
BR,
Vladimir
Andrew_J_1
Hello Vladimir,
Please find the output of the below script attached to this reply:
#!/bin/bash -x
LOG_DIR=amplxe_log
APP="/usr/bin/python test.py"
rm -rf r0*
rm -rf ${LOG_DIR}
rm -rf *.txt
rm -rf pin.*
mkdir ${LOG_DIR}
export AMPLXE_LOG_DIR=$(pwd)/${LOG_DIR}
amplxe-cl -c hotspots /bin/ls |& cat > ls_output.txt
amplxe-cl -c hotspots -mrte-mode=native $APP |& cat > native_app_output.txt
pin -xyzzy -mesgon log_injector -mesgon log_syscall -unique_logfile -- $APP |& cat > pin_output.txt
Interestingly, when I run:
pin -xyzzy -mesgon log_injector -mesgon log_syscall -unique_logfile -- /usr/bin/python test.py
I get the print out of:
Bus error
on my terminal. As such, I ran the above command through GDB, and here is the back-trace:
#0  0x00007ffff7ee02eb in OS_BARESYSCALL_DoCallAsmIntel64Linux () from /opt/intel/vtune_amplifier_xe_2017.3.0.510739/lib64/pinruntime/libc-dynamic.so
#1  0x00007fffffffcd50 in ?? ()
#2  0x00007ffff7ee0424 in BARESYSCALL_Do () from /opt/intel/vtune_amplifier_xe_2017.3.0.510739/lib64/pinruntime/libc-dynamic.so
#3  0x00007ffff7eded36 in OS_SendSignalToThread () from /opt/intel/vtune_amplifier_xe_2017.3.0.510739/lib64/pinruntime/libc-dynamic.so
#4  0x00007ffff7edd8fd in OS_RaiseException () from /opt/intel/vtune_amplifier_xe_2017.3.0.510739/lib64/pinruntime/libc-dynamic.so
#5  0x00007ffff7e8c25a in raise () from /opt/intel/vtune_amplifier_xe_2017.3.0.510739/lib64/pinruntime/libc-dynamic.so
#6  0x00005555558cd0ce in ?? ()
#7  0x00005555558cd1ce in LEVEL_INJECTOR::DoSystemChecks() ()
#8  0x00005555558c1b5e in LEVEL_INJECTOR::UNIX_INJECTOR::Run() ()
#9  0x00005555558c6905 in LEVEL_INJECTOR::PIN_UNIX_ENVIRONMENT::LaunchPin() ()
#10 0x00005555558ae79d in LEVEL_INJECTOR::PIN_ENVIRONMENT::Main() ()
#11 0x0000555555644029 in main ()
I should note that I was previously able to run VTune, but since doing a package upgrade on RHEL, I am susequently unable to run the "basic" hotspots (advanced hotspots still run!). As I mentioned in my earlier response, this problem has persisted even after reinstalling VTune.
Cheers,
Andrew
Vladimir_R_Intel
Andrew,
we suppose that this issue is fixed in the upcoming VTune AXE 2017 U4.
Please make additional actions to file Online Service Center (https://supporttickets.intel.com/?lang=en-US) issue with request for trying updated version of VTune with a fix (you need to refer on this forum thread in OSC request).
In this case we will be able to provide you a pre-release VTune package.
Andrew_J_1
Hi Vladimir,
I actually signed-up for the 2018 "beta" for VTune (version 2018.0.023) -- might these fixes be in 2017 U4?
Cheers,
Andrew
Vladimir_R_Intel
Hi Andrew,
2018 Beta doesn't include these fixes.
VTune 2017 U4 will be the first release with them and then they will be included in 2018 Gold too.
BR,
Vladimir
Andrew_J_1
Hello Vladimir,
I am currently unable to request support for VTune, due to a website issue. I have raised this with another part of Intel that I cannot access the support area.
As soon as that issue is resolved, I will look at getting 2017 U4 of VTune to see if this resolves my issue.
Thanks for your help so far -- cheers,
Andrew
Andrew_J_1
Hello Vladimir, ​Okay, I now have access to the support area. I have raised this issue as request number 02920984. Cheers, Andrew
Andrew_J_1
Hello Vladimir, Unfortunately, because I am currently only an eval customer, Intel's support is unable to give me access to the preview of U4. However, in the mean time, I downgraded my Linux kernel from 3.10.0-514.21.2.el7.x86_64 to 3.10.0-514.21.1.el7.x86_64 (as before, the tiniest of version changes!), and now VTune works again. I have been informed that U4 will be officially released around July 10th; when it comes out, I will check to confirm if this problem persists. Cheers, Andrew
Andrew_J_1
I presume that this issue is related to: https://bugs.centos.org/view.php?id=13453
