- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I run into the following problem when try to collect data:
Collection failed
7/6/2017 3:28:51 PM Collection failed. The data cannot be displayed.
Failed to get a thread handle when attaching to the process due to OS error (Access is denied.
). Data for the thread will not be collected.
The OS: Windows 10.
Target application: MSSQL2014 (sqlservr.exe) and it is Log On as "Network Service", Session 0.
I try to use "Attach to Process" & Basic Hotspots.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Michael,
I suppose that this process is protected from some access rights required for user-mode profiling. In this case I can suggest to use "advanced-hotspots" as a workaround or. to try to come around the basic-hotspots issue. I assume it can be done in the following ways:
1. to decrease protection for a running process if you can control this.
2. to try an instruction for attachment to system processes got from "Troubleshooting" section of Amplifier's help:
Attachment as Administrator to a process that launched by the 'System' user fails (200259643)
You may use a utility from http://technet.microsoft.com/en-us/sysinternals/bb897553 to profile a system service (for example, w3wp.exe-based code) from the command line using amplxe-cl.exe that is located in <product_install_dir>/bin32. Do the following:
Configure the w3wp service to run with the permissions you use to log in: Open IIS Manager, right-click an application pool you are using and set “Process model:Identity” to the account under which w3wp needs to be run.
Run the w3wp service and make sure you run it with proper credentials and remember its PID.
Start data collection:
psexec -i 0 /path/to/amplxe-cl.exe -c=hotspots -r /path/for/your/data_dir --target-pid=PID
Run your workload.
Stop data collection:
psexec -i 0 /path/to/amplxe-cl.exe -command detach -r /path/for/your/data_dir
Open /path/for/your/data_dir in GUI:
<product_install_dir>/bin32/amplxe-gui /path/to/your/data_dir
