Analyzers
5307 Discussions
VTune Amplifier XE crashes during Advanced Hotspot Analysis
Stefan_K_4
I tried to profile my applications with the current VTune Amplifier XE 2013 (Update 12), but when I start an advanced hotspot analysis (no matter for which application), my complete system freezes and even kernel commands (using Ctrl+Alt+SysReq) do not work anymore.
Does anybody experienced similar problems?
I am using Linux Mint 15 with kernel 3.12, but kernel 3.10 also didn't work.
Thanks in advance!
Peter_W_Intel
As l know, if you can downgrade the system to Linux* kernel version to 3.8 (for example, Ubuntu* 13.04), advanced-hotspots can work well.
Bernard
Valued Contributor I
It looks like CPU is spinning to much time in high IRQL(Windows terminology) or staying too much time in ISR.
Stefan_K_4
Downgrading to kernel 3.8 helped. It works perfectly now.
Thank You!
Fabian_W_
I have the same issue with OpenSUSE Tumbleweed with kernel 4.4.3. It works on OpenSUSE 13.2 and OpenSUSE Leap 42.1 (4.1.15).
Any hints to which kernel I need to downgrade? Or are there any other ideas on what I can do?
Fabian_W_
For the records: it seems to work with kernel 4.2.1
Peter_W_Intel
As Release-notes of latest VTune(TM) Amplifier XE 2016 U2 said,  SUSE* Linux* Enterprise Server (SLES) 12 is supported, I estimated that the kernel of SLES 12 is Linux* kernel version 3.12.28 around?
