Analyzers
5297 Discussions
VTune GUI Unable to initialize gtk
Terrence_C_
Hi guys,
I just started exploring VTune trying to identify the hotspot in my program. After I did the "source", I typed "amplxe-gui", but it gave me:
"Error: Unable to initialize gtk, is DISPLAY set properly?"
I searched this problem for a long time but could not find anything related. Can any one help me?
Thanks a lot!
Terrence
Vitaly_S_Intel
Hi Terrence,
Are you working right on the system or using VNC or X forwarding ? Which OS is this system running?
Which script did you "source" before running amplxe-gui? Can you skip it and just run amplxe-gui by absolute path?
Also please make sure you unset DISPLAY environment variable before running amplxe-gui.
Vitaly_S_Intel
Hi Terrence,
Terrence_C_
Hi Vitaly,
Thanks for your quick response!
I managed to make it work by installing quartz, then I do the following:
ssh -X ID@server.addr
source /home/opt/intel/vtune_amplifier_xe_2015.1.1.380310/amplxe-vars.sh
amplxe-gui
Then everything works! I am working from MacOSX and I am trying to submit the job to scheduler now.
Thanks again!
Peter_W_Intel
Share with more people - if they have similar issue.
Here is my inputs: If you use standard Linux distro operation system, or installed GTK and X11 library correctly. amplxe-gui should work. One possibility is that you used vnc server/client for remote access, if you start-up vncserver by root user, use console in in vnc client with non-root user then run amplxe-gui, it will report, Unable to initialize gtk. Just use root user instead.
[Terrence C told me via message] Yes, later on I installed X11 library and everything is fine!
Shaowu_P_
Terrence C. wrote:
Hi Vitaly,
amplxe-gui
Thanks again!
I don't get it. I have the same problem with you. What kind of quartz did you install?
kori__sunil_kumar
I am also facing the same issue and tried to resolve it using above suggestion (by installing quartz) but didn't get any success.
Can someone provide some details on this ?
