Analyzers
5286 Discussions
VTune GUI unable to type on MacOS
Jenny688
I am using VTune 2021.3.0 on MacOS Big SurVersion 11.3.1. I am not able to type in any fields in VTune GUI, for example, to specify the name of a new project. Is there something in the setting that I should change? ( I have launched the VTune Profiler with the vtune-gui command line).
Mariya_P_Intel
Hi  @Jenny688,
Discussed this case with developer. Please source vtune vars from
/opt/intel/oneapi/vtune_profiler/<version >/Intel\ oneAPI\ VTune\ Profiler\ <version>.app/Contents/vtune-vars.sh
before running the vtune-gui and let us know the result.
Thanks, Mariya
AthiraM_Intel
We are working on it internally, will get back to you soon.
Mariya_P_Intel
Hi  @Jenny688,
You may start VTune from the Launchpad.
If you would like to run VTune GUI from the command line, please try:
1. source /opt/intel/oneapi/setvars.sh
  open "Intel oneAPI VTune Profiler 2021.3.0.app"
2. source /opt/intel/oneapi/setvars.sh
  vtune-gui
Thanks, Mariya
Jenny688
Hello Mariya,
Thanks for the help. I have tried both of your options, they don't work, unfortunately. I am not able to launch the application from the Lauchpad. The VTune app will close after 1 second. I am now opening Vtune-gui with the following commands:
. /opt/intel/oneapi/vtune_profiler/latest/env/vars.sh
sudo vtune-gui
In the app, whenever I type in somewhere, what I type appear in the terminal, not on VTune-gui.
Is there something else I can do?
Thank you!
Mariya_P_Intel
Hi  @Jenny688,
Thanks, Mariya
Jenny688
Hello, it works, I am able to type in the application! Thanks a bunch!
Mariya_P_Intel
Hi @Jenny688,
I'm very glad that the issue is solved!
We stop monitoring this thread, please start a new one in case of any further issues.
Thanks, Mariya
