Analyzers
5339 Discussions
VTune Performance Snapshot crashes on simple Java program
Pietruszek
I'm trying to profile a quite small and simple command-line Java program in Intel VTune. I can run the Hotspots/Threading/Memory Access analysis without any issues, but when I run the Performance Snapshot analysis, it crashes.
Here's my configuration from the WHAT pane of VTune:
Launch Application
Application: java.exe
Application parameters: -cp "D:\Users\ZPO\Documents\benchmarksgame\binarytrees\Picked" binarytrees 21
Use application directory as working directory: yes
And here's the output I get:
Picked up JAVA_TOOL_OPTIONS: -agentlib:amplxe_samplingmrte_javaprof_1.0
Error occurred during initialization of VM
Could not find agent library amplxe_samplingmrte_javaprof_1.0 on the library path, with error: Can't find dependent libraries
It looks like the same library is used successfully during the other analyses - the crash only happens when doing the Performance Snapshot analysis.
My Java version:
> java.exe --version
java 11.0.10 2021-01-19 LTS
Java(TM) SE Runtime Environment 18.9 (build 11.0.10+8-LTS-162)
Java HotSpot(TM) 64-Bit Server VM 18.9 (build 11.0.10+8-LTS-162, mixed mode)
My VTune version:
Intel oneAPI VTune Profiler 2021.3.0
Product build: 616728
Gopika_Intel
Thank you for posting in Intel Communities. Could you please share with us the following details so that we can investigate further from our end:
1. Is the result folder getting created? It would be of the form rXXXps
2. The crash log obtained after the crash. It can be obtained by searching vtune logs from %tmp%\amplxe-log-<username> in windows.
Gopika
Pietruszek
1. Yes, the folder does get created
2. I'm attaching all of the logs created after one attempt of running this specific Performance Snapshot
Pietruszek
And since I noticed that my phrasing could potentially be misleading, I'll clarify just to be sure: VTune profiler doesn't crash. When, I close the "almost empty" profiling report, I can continue profiling other things. But running the Performance Snapshot does crash the JVM instance trying to run my Java program. And when it's the Hotspots/Threading/Memory Access analysis, it runs correctly and takes around 6-9 seconds to profile.
Gopika_Intel
Thank you for providing the information. Could you also please share with us the result folder that you obtained after profiling?
Gopika
Gopika_Intel
We are working on this issue internally. We will get back to you soon.
Gopika
Pietruszek
Ok, I'm patiently waiting for this issue to be resolved.
In the meantime I also managed to fetch the requested result folder.
Mariya_P_Intel
Hi @Pietruszek, thanks for sharing the details. Developers are working on this issue. I will notify you when get more info on it.
Pietruszek
Hi! What's the status of the issue? Has the cause at least been found?
Mariya_P_Intel
Hi @Pietruszek, the root cause is found. Please expect the fix in next VTune releases.
vamsi_parasa
I'm an internal user and I have the same problem. Please let me know when the fix is available...
Mariya_P_Intel
Hi @Pietruszek,
The fix is available in VTune 2021.9.0 release.
You may download it here: https://www.intel.com/content/www/us/en/developer/articles/tool/oneapi-standalone-components.html#vtune
Pietruszek
Thank you for the notice @Mariya_P_Intel !
I've downloaded the new version and can confirm that the issue has been fixed on my side!
Mariya_P_Intel
Hi @Pietruszek, thank you for the confirmation.
Feel free to contact Intel support in case of further questions.
