Analyzers
5272 Discussions
VTune XE assertion error on Sandy Bridge processors with 2011 and 2013 versions
Chris_B_3
We are consistently seeing an assertion error when running VTune XE for Linux HotSpot analysis on Sandy Bridge based processors.
VTune versions: vtune_amplifier_xe_2011u8, vtune_amplifier_xe_2013u3
Linux version: Red Hat Enterprise Linux Server release 6.2 (Santiago)
Kernel: 2.6.32-220.23.1
Processor: Intel(R) Xeon(R) CPU E5-2670 0 @ 2.60GHz
Error code:
Assertion '(4 ) + (2 +2 +4 +4 + cpu_no*(2 +leaf_no*(2*4 +4*4 ))) == pos' failed. Please contact the developers.
Assertion '(4 ) + (2 +2 +4 +4 + cpu_no*(2 +leaf_no*(2*4 +4*4 ))) == pos' failed. For more information, please visit the technical support forum at https://software.intel.com/sites/support/
We do not see this with Red Hat 5 / VTune 2011 / Nehalem processors. Can someone shed some light on the error, if it's origin is VTune or the Sandy Bridge architecture, it's severity, and if there is a work-around or fix in the works for it?
Thank you.
Peter_W_Intel
Have you tried latest VTune(TM) Amplifier XE 2013 Update 4?
Are you sure that you used Hotspots collector, not Lightweight-hotspots? What was command line?
If you still have this problem after using U4, can you attach result directory?
Chris_B_3
VTune 2013 Update 4 seems to correct that issue.  Thank you. However, now I am seeing:
Error 0x40000026 (Database interface error) -- Cannot run data transformation `Compute CPU Usage'
When trying to run a summary report on the data collection. I appreciate your assistance.
Peter_W_Intel
It seemed that data collection was OK, and met error when ran:
amplxe-cl -report summary -r result-directory
Is the problem only for summary? Can you do - "amplxe-cl -report hotspots -r result-directory"?
Is it possible that you can attach result directory for invesigating? Thank you.
Chris_B_3
I was able to to 'amplxe-cl -report hotspots -r result-directory.' Thank you, this is resolved.
