Analyzers
5307 Discussions
VTune and Embarcadero C++ Builder 2010
aphesa
Hi all,
i have not seen Embarcadero compilers in the list of supported compilers. Does it mean that VTune will not work at all or that it will just not be possible to integrate it into the Embarcadero environment?
Is it possible to profile a running software outside of a compiler environment?
Thank you.
Arnaud.
Peter_W_Intel
Hi Arnaud,
VTune Analyzeralso supports of analyzing application which was built by other compilers, besides Microsoft* Visual C++ compiler - if the compiler can generate standard binarysuch as PE, COFF format.
Integration mode in Embarcadero environment can't be supported, except Microsoft* Visual Studio. However VTune Analyzer has its standalone application - it means, the user can build application in Embarcadero environment, and generate / analyze program by using this standalone app.
Regards, Peter
