Analyzers
5307 Discussions
VTune crashes on RHEL3u8 trying to view results
olegc
It is a crash report from jrockit. I failed to find a place where I may report it on www.bea.com so port it here.
My system is RHEL3u8 (it is up to date, so it is update 9 but reported as 8 not sure why). My application is built by gcc 3.2.3, i386 (32bit) executable on x86-64/AMD64 platform.
I add my application to the active project and run it. Going to view execution graph make vtlec coredump immediately.
Here is the error message:
JVM terminated. Exit code=1
/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
-Dosgi.splashLocation=/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.intel.sdp.primary_2.0.3/splash.bmp
-Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration
-jar /opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar
-os linux
-ws gtk
-arch x86
-launcher /opt/intel/eclipsepackage/3.2.1/eclipse/eclipse
-name Eclipse
-showsplash 600
-exitdata 60ee006b
-product com.intel.sdp.primary.product
-perspective com.intel.vtune.shell.tuningPerspective
-vm /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
-vmargs
The core file is few hundred Mb. JRockit dump file as follows:
===== BEGIN DUMP =============================================================
JRockit dump produced after 0 days, 00:03:37 on Wed Apr 30 14:54:42 2008
Additional information is available in:
/disk/idun/wrk/vtune/jrockit.14397.dump
/disk/idun/wrk/vtune/core or core.14397
If you see this dump, please open a support case with BEA and
supply as much information as you can on your system setup and
the program you were running. You can also search for solutions
to your problem at http://forums.bea.com in
the forum jrockit.developer.interest.general.
Error Message: Illegal memory access. [54]
Signal info : si_signo=11, si_code=1 si_addr=0xe13bf84
Version : BEA JRockit R27.2.0-131-78843-1.5.0_10-20070320-1511-linux-ia32
GC Mode : Garbage collection optimized for throughput
GC Strategy : Generational Parallel Mark & Sweep
: Current OC phase is: not running. YC is not running.
: GC strategy for GC 0 was singleconcon
: GC strategy for GC 1 was genparpar
: GC strategy for GC 2 was genparpar
& nbsp; : GC strategy for GC 3 was genparpar
: GC strategy for GC 4 was genparpar
: mmHeap->data = 0x40500000, mmHeap->top = 0x44500000
: The nurserylist starts at 0x4097e3c0 and ends at 0x42936950
: mmStartCompaction = 0x40900010, mmEndCompaction = 0x40d00000
: References are 32-bit.
CPU : Intel Pentium 4 SSE SSE2 SSE3 NetBurst EM64T
Number CPUs : 1
Tot Phys Mem : 2072506368 (1976 MB)
OS version : Red Hat Enterprise Linux WS release 3 (Taroon Update 8)
Linux version 2.4.21-53.EL (brewbuilder@hs20-bc2-3.build.redhat.com) (gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-58)) #1 SMP Wed Nov 14 03:46:06 EST 2007 (x86_64)
Thread System: NPTL
State : JVM is running
Command Line : -Dosgi.splashLocation=/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.intel.sdp.primary_2.0.3/splash.bmp -Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration -Dsun.java.launcher=SUN_STANDARD /opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar -os linux -ws gtk -arch x86 -launcher /opt/intel/eclipsepackage/3.2.1/eclipse/eclipse -name Eclipse -showsplash 600 -exitdata 60e18069 -product com.intel.sdp.primary.product -perspective com.intel.vtune.shell.tuningPerspective -vm /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java -vmargs -Dosgi.splashLocation=/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.intel.sdp.primary_2.0.3/splash.bmp -Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration -jar /opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar
java.home : /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10
j.class.path : /opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar
j.lib.path : /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/../lib/i386:/opt/intel/eclipsepackage/3.2.1/eclipse:/opt/intel/vtune/analyzer/bin:/opt/intel/vtune/shared/bin:/opt/sag/gcc-3.4/libem64t:/opt/sag/gcc-3.3/lib32:/opt/sag/gcc-3.3/lib32:/opt/sag/exx/v721/lib:/disk/valhall/openworks/2003.12/oracle/lib:/usr/lib:/disk/valhall/openworks/2003.12/oracle/lib
JAVA_HOME : /usr/java/default
_JAVA_OPTIONS:
LD_LIBRARY_PATH: /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/../lib/i386:/opt/intel/eclipsepackage/3.2.1/eclipse:/opt/intel/vtune/analyzer/bin:/opt/intel/vtune/shared/bin:/opt/sag/gcc-3.4/libem64t:/opt/sag/gcc -3.3/lib32:/opt/sag/gcc-3.3/lib32:/opt/sag/exx/v721/lib:/disk/valhall/openworks/2003.12/oracle/lib:/usr/lib:/disk/valhall/openworks/2003.12/oracle/lib
LD_ASSUME_KERNEL:
C Heap : Good; no memory allocations have failed
StackOverFlow: 0 StackOverFlowErrors have occured
OutOfMemory : 0 OutOfMemoryErrors have occured
Registers (from ThreadContext: 0xfffefc54 / OS context: 0xfffefd50):
eax = 0a13bf88 ecx = 00000008 edx = 03fffffc ebx = 856a224c
esp = ffff0040 ebp = ffff0050 esi = 0a13ec48 edi = ffffffff
es = 0000002b cs = 81720023 ss = 0958002b ds = 0000002b
fs = 00000003 gs = 0000005b
eip = 8569463e eflags = 00200207
Stack:
(* marks the word pointed to by the stack pointer)
ffff0040: ffff0058* 8557572e 0a13ecc4 00000017 ffff0070 85694618
ffff0058: 0a13ec48 ffffffff 0a13ecc4 00000009 8565a85c 8565a85c
ffff0070: ffff015c 855b1647 0a13ec48 ffffffff 9e5b69fc 00000000
ffff0088: 015d6e06 8550dd88 ffff00e8 0aa5d9a4 00000027 0aa5d9c4
Code:
(* marks the word pointed to by the instruction pointer)
8569460c: 08458b04 e8240489 fffd7e5c 5b14c483 8955c35d ec8356e5
85694624: 08758b0c 0f08458b 8b1048b6 e8d30c45 0085148d 8b000000
8569463c: 148b0446* f4558910 8b08558b 423b0c45 8b27720c 45890845
85694654: 0c458bf0 baf04d8b 00000000 890c71f7 458bf055 02e0c1f0
Loaded modules:
(* denotes the module causing the exception)
08048000-08056fd3 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
4002e000-4003aa71 /lib/tls/libpthread.so.0
4003e000-4005ef6f /lib/tls/libm.so.6
40060000-40061e23 /lib/libdl.so.2
40063000-4019546f /lib/tls/libc.so.6
40000000-40014f27 /lib/ld-linux.so.2
4019d000-4043c207 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit/libjvm.so
40018000-4002235b /lib/libnss_files.so.2
40024000-4002be03 /lib/libnss_nis.so.2
404cd000-404deb67 /lib/libnsl.so.1
404be000-404c87db /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libverify.so
8055e000-8057e217 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libjava.so
404e2000-404e7f13 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/native_threads/libhpi.so
404e9000-404f74c4 /opt/intel/eclipsepackag e/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libzip.so
80775000-807860a3 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libnet.so
80b09000-80b0f1e7 /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/libnio.so
80b77000-80bc0e1b /user/olegc/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/74/1/.cp/libswt-pi-gtk-3235.so
80bc3000-80e0591b /usr/lib/libgtk-x11-2.0.so.0
404fa000-404fd3c7 /usr/lib/libgthread-2.0.so.0
80e28000-80e2be87 /usr/X11R6/lib/libXtst.so.6
80e2d000-80e3e7e3 /usr/lib/libgdk_pixbuf-2.0.so.0
80e40000-80ea8727 /usr/lib/libgdk-x11-2.0.so.0
80eae000-80f89223 /usr/X11R6/lib/libX11.so.6
80f8d000-80fac703 /usr/lib/libpangoxft-1.0.so.0
80fae000-80fb952b /usr/lib/libpangox-1.0.so.0
80fbb000-80fe0dc7 /usr/lib/libpango-1.0.so.0
80fed000-810037a3 /usr/lib/libatk-1.0.so.0
81006000-81038cc3 /usr/lib/libgobject-2.0.so.0
8103b000-8103d473 /usr/lib/libgmodule-2.0.so.0
8103f000-810a7c47 /usr/lib/libglib-2.0.so.0
810a9000-810b55e3 /usr/X11R6/lib/libXext.so.6
810b7000-810b910b /usr/X11R6/lib/libXrandr.so.2
810bb000-810c1713 /usr/X11R6/lib/libXi.so.6
810c3000-810d388b /usr/X11R6/lib/libXft.so.2
810d5000-810db7ab /usr/X11R6/lib/libXrender.so.1
810dd000-810ffedb /usr/lib/libfontconfig.so.1
81104000-81153167 /usr/lib/libfreetype.so.6
81158000-81163413 /usr/lib/libz.so.1
81166000-811834f7 /usr/lib/libexpat.so.0
404ca000-404cb75f /usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
81186000-811ab073 /user/olegc/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/74/1/.cp/libswt-gtk-3235.so
80e11000-80e1c653 /usr/lib/gtk-2.0/2.2.0/engines/libbluecurve.so
80e1e000-80e1ef4f /usr/lib/gconv/ISO8859-1.so
80e20000-80e21293 /user/olegc/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/15/1/.cp/os/linux/x86/liblocalfile_1_0_0.so
8126a000-81271723 /usr/X11R6/lib/libXcursor.so.1
81253000-812542ff /usr/lib/pango/1.2.0/modules/pango-basic-xft.so
81273000-8127820f /user/olegc/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/74/1/.cp/libswt-atk-gtk-3235.so
8127a000-812b8b1b /user/olegc/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/74/1/.cp/libcairo-swt.so
812ba000-812c2e87 /user/olegc/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles/74/1/.cp/libswt-cairo-gtk-3235.so
8144b000-8144e5e3 /opt/intel/vtune/shared/bin/libEcGUIClientHandler.so
81451000-814ce38f /opt/intel/vtune/shared/bin/libEcGUIClient.so
814ff000-816a1e07 /opt/sag/gcc-3.3/lib32/libimf.so
80e26000-80e26577 /opt/sag/gcc-3.3/lib32/libcxaguard.so.5
816a4000-816aa f1f /opt/sag/gcc-3.3/lib32/libgcc_s.so.1
816ac000-81749393 /opt/sag/gcc-3.3/lib32/libstdc++.so.5
81764000-818d0343 /opt/sag/exx/v721/lib/libole32.so
818fd000-819a8dab /opt/sag/exx/v721/lib/librpcrt4.so
819bc000-819d6733 /opt/sag/exx/v721/lib/libntrtl.so
819de000-81a5a183 /opt/sag/exx/v721/lib/libmutant.so
81a70000-81a75b27 /opt/sag/exx/v721/lib/libcoolmisc.so
81a78000-81b488af /opt/sag/exx/v721/lib/liboleaut32.so
81b5c000-81be5db3 /opt/intel/vtune/analyzer/bin/libcomfreeremoteconnector.so
81bef000-81c10023 /opt/intel/vtune/shared/bin/libVTUtil.so
81c1b000-81c1dec3 /opt/sag/exx/v721/lib/libcoolcrypto.so
81c20000-81f249ab /opt/intel/vtune/shared/bin/libxerces-c.so.23
82074000-820a1547 /opt/intel/vtune/shared/bin/libRemoteManager.so
820a8000-820acc03 /opt/sag/exx/v721/lib/libbasecrypt.so
820af000-820bfcff /opt/intel/vtune/shared/bin/libVTRegLoc.so
840f6000-8418e09f /opt/intel/vtune/shared/bin/libShell.so
841c7000-841ceed7 /opt/intel/vtune/shared/bin/libShellRes.so
845d1000-845faeaf /opt/intel/vtune/shared/bin/libReports.so
8460d000-84611db7 /opt/intel/vtune/shared/bin/libReportsRes.so
84614000-8462c4eb /opt/intel/vtune/shared/bin/libComInfo.so
84637000-84668ecf /opt/intel/vtune/shared/bin/libProductInfo.so
8467f000-84682537 /opt/intel/vtune/shared/bin/libProductInfoRes.so
8468b000-847463e3 /opt/intel/vtune/shared/bin/libWorkspaceMgr.so
84793000-847972b7 /opt/intel/vtune/shared/bin/libWorkspaceMgrRes.so
8479f000-847e739b /opt/intel/vtune/shared/bin/libCollection.so
84804000-848075b7 /opt/intel/vtune/shared/bin/libCollectionRes.so
8480a000-8491a5b3 /opt/intel/vtune/shared/bin/libActivity.so
84997000-8499e3f7 /opt/intel/vtune/shared/bin/libActivityRes.so
849a7000-849d148b /opt/intel/vtune/shared/bin/libFileDialog.so
849e2000-84a0528b /opt/intel/vtune/shared/bin/libFileDialogEc.so
84a14000-84a45e8f /opt/intel/vtune/shared/bin/libFileMgr.so
84a5d000-84a60cb7 /opt/intel/vtune/shared/bin/libFileMgrRes.so
84a65000-84ae6563 /opt/intel/vtune/shared/bin/libTuningBrowser.so
84b1e000-84b23217 /opt/intel/vtune/shared/bin/libTuningBrowserRes.so
84b26000-84b8c0d3 /opt/intel/vtune/shared/bin/libWorkspaceUI.so
84bbd000-84bc2277 /opt/intel/vtune/shared/bin/libWorkspaceUIRes.so
84bc8000-84c12f3f /opt/intel/vtune/analyzer/bin/libCGAddin.so
84c31000-84c7477b /opt/intel/vtune/analyzer/bin/libAnPropContainers.so
84c90000-84cd7123 /opt/intel/vtune/analyzer/bin/libCGCons4VT.so
84cf4000-84e2844b /opt/intel/vtune/shared/bin/libidvcbase.so
84eba000-84f5f6fb /opt/intel/vtune/analyzer/bin/libCGConsCore.so
84fa3000-84fa7daf /opt/intel/vtune/analyzer/bin/libCGPropStorage.so< br>84faa000-84fd2ef3 /opt/intel/vtune/analyzer/bin/libCGDataModelVTDBC.so
84fe3000-850630a7 /opt/intel/vtune/shared/bin/libidvcfrw.so
85095000-850a750f /opt/intel/vtune/shared/bin/libidvcpilot.so
850af000-851c99ff /opt/intel/vtune/shared/bin/libidvgrid.so
8523c000-852443af /opt/intel/vtune/analyzer/bin/libVTDBRuntime.so
85248000-85253377 /opt/intel/vtune/analyzer/bin/libCGPruner.so
85258000-85270e0f /opt/intel/vtune/analyzer/bin/libVTDBC.so
8527b000-852bf3d3 /opt/intel/vtune/analyzer/bin/libCGDP_VTDBC.so
852dc000-853118bf /opt/intel/vtune/shared/bin/libigvlayout.so
8531c000-8538ce67 /opt/intel/vtune/shared/bin/libigvviewer.so
853ca000-853da457 /opt/intel/vtune/shared/bin/libigvgraph.so
853e1000-853e746b /opt/intel/vtune/shared/bin/libigvdatamanager.so
853eb000-85433b83 /opt/intel/vtune/analyzer/bin/libvtsdb.so
8544f000-854a2c8b /opt/intel/vtune/analyzer/bin/libCTCG.so
854c2000-854c88c3 /opt/intel/vtune/shared/bin/libdbmanager.so
854cc000-854f585b /opt/intel/vtune/analyzer/bin/libSymbolProvider_VTDBC.so
85507000-855fc0f3 /opt/intel/vtune/shared/bin/libismImpl_2.so
85661000-8569a4d7 */opt/intel/vtune/shared/bin/libcommon_2.so
856a3000-856b6c9f /opt/intel/vtune/shared/bin/libsupport_2.so
85800000-8580e8c7 /opt/intel/vtune/shared/bin/libdtlu_trace_assert.so
85816000-85851857 /opt/intel/vtune/shared/bin/libvtfamgr.so
8599c000-859a424f /opt/intel/vtune/shared/bin/libVTAddr_2.so
859a8000-859e5dcb /opt/intel/vtune/shared/bin/libSymVSrvr.so
85a02000-85a201f7 /opt/intel/vtune/shared/bin/libDynamicLoading_2.so
85a2e000-85a8f253 /opt/intel/vtune/analyzer/bin/libCGImpExp.so
85ab2000-85abf9bb /opt/intel/vtune/analyzer/bin/libVTSDBUtil.so
85ac6000-85b30a03 /opt/intel/vtune/analyzer/bin/libCGPackNGo.so
85b5b000-85b7f1f7 /opt/intel/vtune/analyzer/bin/libAnalyzerWizardsAddin.so
85b8f000-85c20353 /opt/intel/vtune/analyzer/bin/libAnProdInfo.so
85c44000-85c484f7 /opt/intel/vtune/analyzer/bin/libAnProdInfoRes.so
85c63000-85c66133 /lib/libnss_dns.so.2
85c68000-85c7679f /lib/libresolv.so.2
85c7a000-85ca0f17 /opt/intel/vtune/analyzer/bin/libEcAnalyzerUtils.so
85cb1000-85cf8fe7 /opt/intel/vtune/analyzer/bin/libSVConsumerEc.so
85c4c000-85c5b0db /opt/intel/vtune/analyzer/bin/libsv_vtune_u.so
85d16000-85d30a3f /opt/intel/vtune/analyzer/bin/libsvpropstorage_u.so
85d3b000-85dd8e1f /opt/intel/vtune/analyzer/bin/libsvcore_u.so
85e13000-85e3735f /opt/intel/vtune/analyzer/bin/libsvcontrol_u.so
85e47000-85e5659f /opt/intel/vtune/analyzer/bin/libVtGridCtlLite_u.so
85e5d000-85f9249b /opt/intel/vtune/shared/bin/libidvcbase_u.so
86024000-8605b9b7 /opt/intel/vtune/shared/bin/libdtlu_file.so
8 616d000-861de8bb /opt/intel/vtune/analyzer/bin/libsvdp.so
86201000-8620c54f /opt/intel/vtune/analyzer/bin/libsv_pi.so
86212000-8632e82f /opt/intel/vtune/shared/bin/libidvgrid_u.so
863a2000-863da19f /opt/intel/vtune/shared/bin/libidvtextviewer_u.so
863f4000-8640a62b /opt/intel/vtune/analyzer/bin/liblipsdp.so
86414000-8643f2d7 /opt/intel/vtune/analyzer/bin/libsv_dedp.so
86451000-8645e207 /opt/intel/vtune/analyzer/bin/libsv_do.so
86464000-86473c2f /opt/intel/vtune/analyzer/bin/libsv_mh.so
8647a000-864af93f /opt/intel/vtune/analyzer/bin/liblips.so
866d5000-866e30d7 /opt/intel/vtune/analyzer/bin/libsv_ei.so
866ea000-866ef4ff /opt/intel/vtune/analyzer/bin/libbemrl.so
866f1000-866fad2f /opt/intel/vtune/analyzer/bin/libemrlcore.so
86712000-8672e0f8 /opt/intel/vtune/analyzer/bin/libdecem.so
8678e000-8679d693 /opt/intel/vtune/analyzer/bin/libdisem.so
867a2000-867b3e95 /opt/intel/vtune/analyzer/bin/libdasm.so
867bd000-867c92bf /opt/intel/vtune/analyzer/bin/libdisxsc.so
867cb000-867d7a5f /opt/intel/vtune/analyzer/bin/libdecxsc.so
867da000-86836d4b /opt/intel/vtune/analyzer/bin/libdecoder.so
86838000-86882f7f /opt/intel/vtune/shared/bin/libEnvInfo.so
868a5000-868a8a17 /opt/intel/vtune/shared/bin/libcpuinfo2.so.1
868aa000-868ae48f /opt/intel/vtune/shared/bin/libcpuinfoxsc.so.1
868b1000-868b6a57 /opt/intel/vtune/shared/bin/libEnvInfoRes.so
868b9000-86917a23 /opt/intel/vtune/analyzer/bin/libSamplingConsumerEc.so
8693f000-86a92587 /opt/intel/vtune/analyzer/bin/libSamplingViewerCore.so
86b20000-86ba025f /opt/intel/vtune/shared/bin/libidvcfrw_u.so
86bd2000-86c7deb7 /opt/intel/vtune/shared/bin/libidvtimeline_u.so
86db7000-86e120ff /opt/intel/vtune/shared/bin/libidvchart_u.so
86e35000-86e66a27 /opt/intel/vtune/shared/bin/libidvchartelements_u.so
86e78000-86ff563b /opt/intel/vtune/analyzer/bin/libSPLMDEDataMgr.so
8709f000-870ead6f /opt/intel/vtune/analyzer/bin/libVTDBJoin.so
87106000-8712419f /opt/intel/vtune/analyzer/bin/libSamplingPropContainersEc.so
87131000-87236caf /opt/intel/vtune/analyzer/bin/libModuleHandler.so
872a2000-8732f1e3 /opt/intel/vtune/shared/bin/libvtfilehandler.so
87379000-873b640f /opt/intel/vtune/analyzer/bin/libOptrepAddin.so
873d0000-873e0d17 /opt/intel/vtune/analyzer/bin/libOptRepControl.so
873e7000-873faee3 /opt/intel/vtune/analyzer/bin/libOptReportParser.so
87402000-87404167 /opt/intel/vtune/analyzer/bin/libOptRepEcClient.so
87406000-874830bb /opt/intel/vtune/shared/bin/libidvcswt_u.so
874bf000-87503657 /opt/intel/vtune/analyzer/bin/libRatiosEditor.so
8751e000-87537d0b /opt/intel/vtune/analyzer/bin/libEvents.so
87540000-8758763f /opt/intel/vtune/shared/bin/libFil eSearchAddIn.so
875a7000-875f29af /opt/intel/vtune/shared/bin/libActivityEc.so
87611000-8764b4ef /opt/intel/vtune/analyzer/bin/libCGPreferencePagesEC.so
87661000-8768644f /opt/intel/vtune/analyzer/bin/libSVPreferencePagesEC.so
87696000-876eba3f /opt/intel/vtune/analyzer/bin/libSamplingPreferencesPagesEc.so
8770d000-8774a80f /opt/intel/vtune/analyzer/bin/libVTMHPrefPagesEc.so
87765000-87799de7 /opt/intel/vtune/shared/bin/libFileSearchPrefPagesEc.so
87fb2000-8801550b /opt/intel/vtune/shared/bin/libVTRun.so
8803f000-88043d17 /opt/intel/vtune/shared/bin/libVTRunRes.so
8804c000-8805f58b /opt/sag/exx/v721/lib/libsecurity.so
8c067000-8c08cabf /opt/intel/vtune/shared/bin/libPropBag.so
877b1000-877f6aa7 /opt/intel/vtune/analyzer/bin/libSamplingWizardLogic.so
87812000-87835a2f /opt/intel/vtune/analyzer/bin/libSamplingWizardEc.so
87844000-879afa47 /opt/intel/vtune/analyzer/bin/libtebscollector.so
87a3d000-87a56c4b /opt/intel/vtune/analyzer/bin/libsera.so
87a61000-87a6bc17 /opt/intel/vtune/analyzer/bin/libseli.so
87a6e000-87ae3057 /opt/intel/vtune/analyzer/bin/libvtsa_gen.so
87b01000-87b18e5b /opt/intel/vtune/analyzer/bin/libeventBase.so
87b23000-87b7910f /opt/intel/vtune/analyzer/bin/libVTEventsMgr.so
87b9b000-87b9ea3b /opt/intel/vtune/analyzer/bin/libsep_adapter.so
8c0a4000-8c0b1877 /opt/intel/vtune/analyzer/bin/libsep_parser.so
87ba1000-87ba75c7 /opt/intel/vtune/analyzer/bin/libsamp_envinfo.so
87baa000-87bae1c7 /opt/intel/vtune/analyzer/bin/libsampling_collector.so
8c0b8000-8c0c3b57 /opt/intel/vtune/analyzer/bin/libtbsana.so
8c0c7000-8c0d0927 /opt/intel/vtune/analyzer/bin/librun_handler.so
8c14c000-8c153f4f /opt/intel/vtune/analyzer/bin/libruns_manager.so
8c157000-8c161adf /opt/intel/vtune/analyzer/bin/libcasi.so
8c163000-8c16d3b3 /opt/intel/vtune/analyzer/bin/libVtuneApiSamp.so
8c171000-8c185aa7 /opt/intel/vtune/analyzer/bin/libtbs32nx.so
8c18c000-8c194287 /opt/intel/vtune/analyzer/bin/libvtsa_cnc.so
8c197000-8c1c544f /opt/intel/vtune/analyzer/bin/libvtremoteconnector.so
8e1d9000-8e1dfb07 /opt/intel/vtune/shared/bin/libActivityps.so
8e1e3000-8e1e64d7 /opt/intel/vtune/shared/bin/libActivityHps.so
9424c000-94289e93 /opt/intel/vtune/shared/bin/libFileCopier.so
982a2000-982d4853 /opt/intel/vtune/analyzer/bin/libtebsproxyexecontroller.so
81383000-81388d47 /opt/intel/vtune/shared/bin/libVTRunps.so
8e20f000-8e238f3b /opt/intel/vtune/shared/bin/libDataObject.so
982ea000-982f4607 /opt/intel/vtune/shared/bin/libfflELF64_2.so
9e598000-9e5a2713 /opt/intel/vtune/shared/bin/libfflELF_2.so
9e5a7000-9e5d7243 /opt/intel/vtune/shared/bin/libdilDWARF32_2.so
9e5ef000-9e5fad03 /opt/intel/vtune/shared/b in/libdilSTABS_2.so
9e600000-9e608ba3 /opt/intel/vtune/shared/bin/libfflISM_2.so
9e60c000-9e627b97 /opt/intel/vtune/analyzer/bin/libAnalyzerResources.so
9e631000-9e709647 /opt/intel/vtune/analyzer/bin/libMiniDE.so
9e75c000-9e8a3cd3 /opt/intel/vtune/analyzer/bin/libDBMgr.so
9e927000-9e958cab /opt/intel/vtune/analyzer/bin/libMiniDEProxy.so
9e96c000-9e98596f /opt/intel/vtune/analyzer/bin/libDBLtoVTDB.so
9e991000-9ea074b3 /opt/intel/vtune/analyzer/bin/libRatios.so
9ea34000-9ea632a3 /opt/intel/vtune/analyzer/bin/libVTFormulaEngine.so
9ea79000-9eaaf137 /opt/intel/vtune/analyzer/bin/libSamplingConsumerEcClient.so
9eacb000-9ead1957 /opt/intel/vtune/shared/bin/libidvcjni_u.so
"Main Thread" id=1 idx=0x4 tid=14397 lastJavaFrame=0xffff68c0
Stack 0: start=0xffdfe000, end=0xffffe000, guards=0xffe03000 (ok), forbidden=0xffe01000
Thread Stack Trace:
at _ZNK15TChunkArrayImplIP14VTSectionImpl1E2atEm+32()@0x8569463e
at _ZNK15TChunkArrayImplIP14VTSectionImpl1EixEm+36()@0x85694618
at _ZN19CFileSymbolBankImpl13CalcAsmLengthEv+967(FileSymbolBankImpl.cpp)@0x855b1647
at _ZN19CFileSymbolBankImpl12LoadLineInfoEv+3027(FileSymbolBankImpl.cpp)@0x855aae37
at _ZN19CFileSymbolBankImpl13CreateISMFileEPw+9146(FileSymbolBankImpl.cpp)@0x85599426
at _ZN18CAppSymbolBankImpl16AddPersistFileSVEP10VTModuleID9VTAddressP19INotifyProgressImplmPP19IFileSymbolBankImpl+3621(AppSymbolBankImpl.cpp)@0x85545ff9
at _ZN18CAppSymbolBankImpl16AddPersistFileSVEP10VTModuleID9VTAddressP19INotifyProgressImplmPP20IFileSymbolBankImpl5+104()@0x85566520
at _ZN17CVTSymbolProvider4InitEv+650(VTSymbolProvider.cpp)@0x854e1836
at (???.c)@0x9e9441ec
at (???.c)@0x9e6db9b8
at (???.c)@0x9e6f80ef
at (???.c)@0x9e6f1f08
at (???.c)@0x9e6ef1c5
at (???.c)@0x9e66e5d9
at (???.c)@0x9e661356
at (???.c)@0x9e677e6f
at (???.c)@0x86f1beac
at (???.c)@0x86f5f14f
at (???.c)@0x86a27425
at (???.c)@0x86a4fd77
at (???.c)@0x869db63a
at (???.c)@0x869cd35e
at _ZN7idvgrid5CGrid10OnDblClickEii+112()@0x8626c6fc
at _ZN7idvgrid5CGrid13OnDoubleClickEPN4idvc11CMouseEventE+285()@0x86266881
at _ZThn32_N7idvgrid5CGrid13OnDoubleClickEPN4idvc11CMouseEventE+35()@0x86273eef
  ; at _ZN4idvc16CImplEventSenderINS_10ISysWindowEE9FireEventERKSt9type_infoMNS_7INotifyEFvPNS_6CEventEES8_b+119()@0x85f6e82f
at _ZN4idvc12JIDVCWrapper21mouseDoubleClickEventEP8_jobject+484()@0x87458e88
at _Z21SWTOnMouseDoubleClickPvP8_jobject+43()@0x8743f1df
at Java_com_intel_vtune_idvclibuni_IDVCanvas_OnMouseDoubleClick+49()@0x9ead1509
-- Java stack --
at com/intel/vtune/idvclibuni/IDVCanvas.OnMouseDoubleClick(JLorg/eclipse/swt/events/MouseEvent;)V(Native Method)
at com/intel/vtune/idvclibuni/IDVCanvas.access$1200(IDVCanvas.java:21)
at com/intel/vtune/idvclibuni/IDVCanvas$6.mouseDoubleClick(IDVCanvas.java:430)
at org/eclipse/swt/widgets/TypedListener.handleEvent(TypedListener.java:141)
at org/eclipse/swt/widgets/EventTable.sendEvent(EventTable.java:66)
at org/eclipse/swt/widgets/Widget.sendEvent(Widget.java:1085)
at org/eclipse/swt/widgets/Display.runDeferredEvents(Display.java:3166)
at org/eclipse/swt/widgets/Display.readAndDispatch(Display.java:2842)
at org/eclipse/ui/internal/Workbench.runEventLoop(Workbench.java:1914)
at org/eclipse/ui/internal/Workbench.runUI(Workbench.java:1878)
at org/eclipse/ui/internal/Workbench.createAndRunWorkbench(Workbench.java:419)
at org/eclipse/ui/PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org/eclipse/ui/internal/ide/IDEApplication.run(IDEApplication.java:95)
at org/eclipse/core/internal/runtime/PlatformActivator$1.run(PlatformActivator.java:78)
at org/eclipse/core/runtime/internal/adaptor/EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org/eclipse/core/runtime/internal/adaptor/EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org/eclipse/core/runtime/adaptor/EclipseStarter.run(EclipseStarter.java:400)
at org/eclipse/core/runtime/adaptor/EclipseStarter.run(EclipseStarter.java:177)
at jrockit/vm/RNI.c2java(IIII)V(Native Method)
at jrockit/vm/Reflect.invokeMethod(Ljava/lang/Object;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;(Native Method)
at sun/reflect/NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;(Native Method)
at sun/reflect/NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun/reflect/DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java/lang/reflect/Method.invoke(Method.java:585)
at org/eclipse/core/launcher/Main.invokeFramework(Main.java:336)
at org/eclipse/core/launcher/Main.basicRun(Main.java:280)< br> at org/eclipse/core/launcher/Main.run(Main.java:977)
at org/eclipse/core/launcher/Main.main(Main.java:952)
-- end of trace
Extended, platform specific info:
libc release: 2.3.2-stable
Elf headers:
libc ehdrs: EI: 7f454c46010101000000000000000000 ET: 3 EM: 3 V: 1 ENTRY: 00015880 PHOFF: 00000034 SHOFF: 0017f7b4 EF: 0x0 HS: 52 PS: 32 PHN; 9 SS: 40 SHN: 61 STIDX: 60
libpthread ehdrs: EI: 7f454c46010101000000000000000000 ET: 3 EM: 3 V: 1 ENTRY: 00004700 PHOFF: 00000034 SHOFF: 00017900 EF: 0x0 HS: 52 PS: 32 PHN; 8 SS: 40 SHN: 34 STIDX: 33
libjvm ehdrs: EI: 7f454c46010101000000000000000000 ET: 3 EM: 3 V: 1 ENTRY: 00057470 PHOFF: 00000034 SHOFF: 002dfe00 EF: 0x0 HS: 52 PS: 32 PHN; 4 SS: 40 SHN: 19 STIDX: 16
===== END DUMP ===============================================================
Thomas_W_Intel
Thank you for reporting this issue. Can you submit it on http://premier.intel.com/ ? This way, it will be enter the issue database and be reviewed by the VTune team.
Thanks in advance
Thomas
