Hi, all.
When I launch VTune for Fortran project, see error:
I saw the same issue mentioned in a related thread, but that was for the i7-2600K. I'm using the 12th Gen Intel® Core™ i7-12700H processor and the latest version of VTune 2024.1. Why am I still experiencing this problem?What can be done to fix this?
- « Previous
- 1
- 2
- Next »
It seems like the issue you're encountering with VTune Profiler is related to it not recognizing the microarchitecture of your processor, the Intel Core i7-12700H. Despite using the latest version of VTune Profiler (2024.1), it's still not recognizing the processor.
Given that you're using a relatively new processor, there could be a few reasons for this problem:
1. **Compatibility**: There might be an incompatibility issue between VTune Profiler version 2024.1 and the microarchitecture of your processor.
2. **Microarchitecture Support**: VTune Profiler might not have been updated to support the microarchitecture of the 12th Gen Intel Core processors, including the i7-12700H.
3. **Bug or Configuration Issue**: There could be a bug in the software or a configuration issue causing it to not recognize the processor correctly.
To address this problem, you can try the following steps:
1. **Check for Updates**: Even though you're using the latest version of VTune Profiler, it's possible that Intel has released a newer update or patch specifically addressing issues with the 12th Gen Intel Core processors. Check for any available updates or patches for VTune Profiler.
2. **Contact Support**: If you haven't already, consider reaching out to Intel's support team or the Online Service Center mentioned in the error message. They may have additional insights or provide you with a solution, especially if the issue is related to a new or unreleased processor.
3. **Alternative Tools**: If you need to perform performance analysis on your Fortran project urgently and cannot resolve the issue with VTune Profiler, consider exploring alternative performance analysis tools that support your processor architecture.
4. **Documentation and Forums**: Search through Intel's documentation, forums, and community boards to see if other users have encountered similar issues and if any workarounds or solutions have been suggested.
5. **Configuration Check**: Ensure that your VTune Profiler installation is properly configured and that there are no conflicting settings or issues with your system setup that could be causing the problem.
By following these steps and potentially consulting with Intel's support resources, you should be able to diagnose and hopefully resolve the issue with VTune Profiler not recognizing the microarchitecture of your Intel Core i7-12700H processor.
The issue may stem from VTune Profiler 2024.1 not fully supporting the 12th Gen Intel® Core™ i7-12700H processor. Ensure you have the latest VTune updates or patches installed. If the problem persists, contact Intel Support for assistance and check for any specific patches or updates for your CPU model.
It seems VTune Profiler hasn't updated its database to recognize the 12th Gen Intel® Core™ i7-12700H processor. Try reaching out to Intel's support or checking for software updates to resolve the compatibility issue.
Could you share some information on your system:
1. Please check what antivirus is active on your system. It will be available at "Windows Security"->"Virus & threat protection"
The output of the command: asysteminfo | findstr /B /C:"OS Name" /B /C:"OS Version" and the value of AntivirusSignatureVersion are null.
The root cause is found and the bug will be fixed in a future release. Thanks.
i Also using the 12th Gen Intel® Core™ i7-12700H processor and getting Same Issue
VTune 2024.2.1 will fix the issue.
- « Previous
- 1
- 2
- Next »
You should see something like this - not necessarily CrowdStrike
2. Please share the output of the following command as well on all the systems: systeminfo | findstr /B /C:"OS Name" /B /C:"OS Version"
