Analyzers
5314 Discussions
VTune fails: ProcessSectionHeaders: 927: unknown section type 0x6fff4c04
wenzeljakob
I am unable to profile applications using VTune, which fails using the following error message
$ /opt/intel/vtune_profiler_2020/bin64/vtune --collect threading my_application
tune: Collection started. To stop the collection, either press CTRL-C or enter from another console window: vtune -r /home/wjakob/enoki-jit/r003tr -command stop.
vtune: Error: [Instrumentation Engine]: Source/pin/elfio/img_elf.cpp: ProcessSectionHeaders: 927: unknown section type 0x6fff4c04 for sec[150,.deplibs] in /lib/x86_64-linux-gnu/libc++.so.1
vtune: Collection failed.
vtune: Internal Error
The issue seems highly reminiscent to the following forum message, where the workaround was to use hardware-based sampling. I was interested in "--collect threading" mode, where that variant is not available, however.
In case it is relevant, this program was built using Clang 10 with libc++. I am using the latest version of VTune (2020_update3) on  Ubuntu 20.04.
Any suggestions would be greatly appreciated,
Wenzel Jakob
wenzeljakob
Great, thank you! I can compile with GCC/libstdc++ for now, but it's nice to hear that libc++ will be supported.
wenzeljakob
A potentially useful data point regarding this issue: if the application is built using GCC (& linked against libstdc++), everything works as expected.  But building a C++ application using Clang 10, and linking against libstdc++ appears to cause the issue.
Kirill_U_Intel
There is hardware version of threading analysis. We could not catch sync objects in such case but probably you find what you need.
vtune -collect threading -knob sampling-and-waits=hw
 It will be great if you share small source reproducer with compiler/linker flags to try that on our side.
Thanks, Kirill
wenzeljakob
Doesn't take much to reproduce
#include <iostream>
int main(int, char **) {
    std::cout << "Hello world" << std::endl;
 To compile:
$ clang++ test.cpp -o test -stdlib=libc++
$ /opt/intel/vtune_profiler_2020/bin64/vtune --collect threading test
This involves the following packages (on Ubuntu 20.04):
ii clang 1:10.0-50~exp1 amd64 C, C++ and Objective-C compiler (LLVM based)
ii libllvm10:amd64 1:10.0.0-4ubuntu1 amd64 Modular compiler and toolchain technologies, runtime library
ii llvm-10 1:10.0.0-4ubuntu1 amd64 Modular compiler and toolchain technologies
ii libc++-10-dev:amd64 1:10.0.0-4ubuntu1 amd64 LLVM C++ Standard library (development files)
ii libc++-dev:amd64 1:10.0-50~exp1 amd64 LLVM C++ Standard library (development files)
ii libc++1-10:amd64 1:10.0.0-4ubuntu1 amd64 LLVM C++ Standard library
ii libc++abi-10-dev:amd64 1:10.0.0-4ubuntu1 amd64 LLVM low level support for a standard C++ library (development files)
ii libc++abi-dev:amd64 1:10.0-50~exp1 amd64 LLVM low level support for a standard C++ library (development files)
ii libc++abi1-10:amd64 1:10.0.0-4ubuntu1 amd64 LLVM low level support for a standard C++ library
Vladimir_T_Intel
Hi wenzeljakob,
Thanks for the reproducer! The bug has been fixed and the fix will show-up in the next public release. But if you need to have it quickly with an intermediate build, you'd need to create a ticket in the http://supporttickets.intel.com/ (just mention a link to this forum thread in ticket).
-Vladimir
wenzeljakob
wenzeljakob
Oops, I mis-clicked and selected my own post as "solution" -- sorry about that!
AthiraM_Intel
Glad to know that your issue is resolved. We won't be monitoring this thread anymore. Kindly raise a new thread if you need further assistance.
