Analyzers
5279 Discussions
VTune performance-snapshot crashes with "Assertion failed: res != TPSS_FALSE"
Borys_Minaiev
Hi!
On my machine both "performance-snapshot" and "memory access" crashes with:
file: vcs/perfrun1/plugins/system/src/benchmark.cpp:758
Other types of collections work fine.
Attached self-checker-report, which shows failures. OS is Ubuntu 21.10.
Sampling drivers are loaded correctly:
$ ./insmod-sep -q
pax driver is loaded and owned by group "vtune" with file permissions "660".
socperf3 driver is loaded and owned by group "vtune" with file permissions "660".
sep5 driver is loaded and owned by group "vtune" with file permissions "660".
socwatch driver is loaded and owned by group "vtune" with file permissions "660".
vtsspp driver is loaded and owned by group "vtune" with file permissions "660".
Probably something is wrong with my environment, but I have no idea where to look at.
Any ideas how to fix it?
Rahila_T_Intel
We tried the same in Ubuntu 21.10 using VTune 2022.1.0. We were able to run all the applications successfully. Attaching the screenshot of self checker for your reference.
Could you please uninstall and install the VTune and try to run the same again.
If the issue still persist please let us know.
Borys_Minaiev
I tried to reinstall VTune (even used newer version 2022.2.0-nda), but still saw the same assertion (but with a little bit different line number now):
  file: vcs/perfrun1/plugins/system/src/benchmark.cpp:747
Attached new self-checker log file if it could help to understand the problem.
Also what is the correct way of uninstalling VTune? I just run "sudo rm -rf /opt/intel/oneapi/" - not sure if VTune also stores additional information somewhere.
Rahila_T_Intel
We could see that you are using nda version of VTune. Please let us know whether you have priority support ?
Borys_Minaiev
No, I don't have a priority support.
Nda version was downloaded automatically by the installer, I haven't done anything special to get it. Initial failure was on usual 2022.01 version.
Rahila_T_Intel
We are working on this internally. we will get back to you as soon as we get an update
Rahila_T_Intel
Could you please share the link from where you downloaded the VTune.
We could see that you got nda version. Those who got nda version will have priority support and those can raise ticket in https://software.intel.com/content/www/us/en/develop/support/priority-support.html
Rahila_T_Intel
We have not heard back from you. We hope that you got some clarity regarding the query which you raised. Could you please give us an update ?
Rahila_T_Intel
Borys_Minaiev
Hey!
Sorry, it's been a while since I posted this question, so unfortunately I don't remember which link I used to download the installer.
Since then I have already updated my Ubuntu to version 22.04 and reinstalled a bunch of software (including VTune). Some of it helped and currently VTune works fine for me, so I can't help with reproducing this error anymore.
Anyway, thanks for investigating!
Rahila_T_Intel
Thanks for the update.
Please let us know if we can go ahead and close this case.
Borys_Minaiev
Sure, go ahead!
Rahila_T_Intel
Thanks for the confirmation. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
