Analyzers
5315 Discussions
VTune result file gets lost during using vtune-backend
howin
I started a web server to check vtune result file under directory /tmp/vt.
`vtune/2022.3.0/bin64/vtune-backend --web-port=8080 --data-directory="/tmp/vt" --allow-remote-access`
Everything works fine. However, after I restarting the vtune-backend, some result files become empty. Why? Is there any solution for recovering the missing files?
The version info. is Intel(R) VTune(TM) Profiler 2022.3.0 (build 624050) Command Line Tool.
AlekhyaV_Intel
Good day to you!
Thank you for posting in Intel Communities. Could you please follow the below suggestions and let us know if the issue still persists or not:
  1. Try updating VTune to latest version from here(https://www.intel.com/content/www/us/en/developer/tools/oneapi/vtune-profiler-download.html)
  2. Try avoiding using /tmp directory while working with VTune. Instead, you could try creating a new result directory somewhere in a home folder and check if the files are missing are not.
If this resolves your issue, make sure to accept it as a solution. This helps others with similar issue. Thanks in advance!
Alekhya
AlekhyaV_Intel
Has the solution provided helped? Could you please give us an update regarding this issue?
Alekhya
JaideepK_Intel
Good day to you.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
