Analyzers
5297 Discussions
Does Intel Advisor and VTune only work with Intel CPUs?
markosoft
Is an Intel CPU necessary to run Advisor and VTune or they also work also with AMD ones? Is there any benefit in using Intel compiler to compile the code, instead of GCC, if then the application will be profiled with one of the two tools?
Thanks in advance.
JaideepK_Intel
The list of supported processors is contained in the release notes. Only genuine Intel processors are supported.
Please check the below system requirements link.
link: Intel® VTune™ Profiler System Requirements
We expect there will be some good runtime performance on the intel processors while using intel compilers. Please refer to the below links for more information.
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top.html
https://www.intel.com/content/www/us/en/developer/articles/technical/adoption-of-llvm-complete-icx.html#inpage-nav-7
Irrespective of any compiler, you can run any binary or executable on both the Advisor and Vtune.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
Good day to you.
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
