Analyzers
VTune
Bernasek__Franz
the Vtune does not work with Intel Xeon E5-2697v2 CPU,
oneAPI 2024 is for me unusable and flies out
I will certainly not exchange my ten workstations based on E5-2697v2 because of this
regards
Franz
yuzhang3_intel
Please provide the information below, thanks.
  1. OS and VTune version
  2. The error message
  3. The output from the command line below
          $ sep -version
Bernasek__Franz
for the Vtune Problem , the needed data
regards
Franz
yuzhang3_intel
This is a list of Xeon platforms supported by VTune 2024.2. The current release only supports platforms newer than Haswell. You need to use the older release for older platform support.
yuzhang3@yuzhang3-10710:~$ sep -pl
Platform: 99, PMU: haswell_server, Signature: 0x306f0, CPU name: Intel(R) Xeon(R) E5/E7 v3 Processor code named Haswell
Platform: 108, PMU: broadwell_server, Signature: 0x406f0, CPU name: Intel(R) Xeon(R) Processor code named Broadwell
Platform: 111, PMU: skylake_server, Signature: 0x50650, CPU name: Intel(R) Xeon(R) Processor code named Skylake
Platform: 124, PMU: skylake_server, Signature: 0x50652, CPU name: Intel(R) Xeon(R) Processor code named Skylake W
Platform: 125, PMU: icelake_server, Signature: 0x606a0, CPU name: Intel(R) Xeon(R) Processor code named Icelake
Platform: 127, PMU: cascadelake_server, Signature: 0x50655, CPU name: Intel(R) Xeon(R) Processor code named Cascadelake
Platform: 128, PMU: snowridge, Signature: 0x80660, CPU name: Intel(R) Xeon(R) Processor code named Snowridge
Platform: 131, PMU: sapphirerapids_server, Signature: 0x806f0, CPU name: Intel(R) Xeon(R) Processor code named Sapphirerapids
Platform: 132, PMU: cascadelake_server, Signature: 0x5065a, CPU name: Intel(R) Xeon(R) Processor code named Cooperlake
Platform: 139, PMU: skylake_server, Signature: 0x50680, CPU name: Intel(R) Xeon(R) Processor code named Ashcreekfalls
Platform: 157, PMU: emeraldrapids_server, Signature: 0xc06f0, CPU name: Intel(R) Xeon(R) Processor code named Emeraldrapids
Platform: 158, PMU: grandridge, Signature: 0xb0660, CPU name: Intel(R) Xeon(R) Processor code named Grandridge
Platform: 159, PMU: sierraforest_server, Signature: 0xa06f0, CPU name: Intel(R) Xeon(R) Processor code named Sierraforest
Bernasek__Franz
Hi
As I see it,
there is no practical solution in sight, I will probably have to switch to AMD after 20 years of being an Intel user
regards
Franz
