- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Recently I was using VTune to profile some parallel benchmarks. I found some programs took much longer time to execute on vtune than directly executing them. After some tests, I found that the system function "getc" is very slow when I use VTune, therefore the time of loading big input files is very long. To make this scenario easy to reproduce, I compiled a simple md5sum program (ftp://quatramaran.ens.fr/pub/madore/misc/md5sum.c) which calls getc and then do a concurrency analysis on VTune.
$ gcc -o md5sum -g -O2 md5sum.c
$ time ./md5sum webdocs_250k.dat
f44f49ac4fb609005ba3bd2fb511df54 webdocs_250k.dat
real 0m2.997s
user 0m2.959s
sys 0m0.036s
$ amplxe-cl -collect concurrency -knob enable-user-tasks=true -- ./md5sum webdocs_250k.dat
Using result path `/home/zhang/parsec-3.0/pkgs/apps/freqmine/run/r005cc'
Executing actions 34 % Resolving information for `libc-2.3.4.so'
Warning: Cannot locate symbols for file `/opt/intel/vtune_amplifier_xe_2013/lib64/pinruntime/glibc/libc-2.3.4.so'.
Executing actions 36 % Resolving information for `libc-2.12.so'
Warning: Cannot locate symbols for file `/lib64/libc-2.12.so'.
Executing actions 36 % Resolving information for `libtpsstool.so'
Warning: Cannot locate symbols for file `/opt/intel/vtune_amplifier_xe_2013/lib64/libtpsstool.so'.
Executing actions 50 % Generating a report
Summary
Average Concurrency: 1.000
Elapsed Time: 135.801
CPU Time: 135.798
Wait Time: 0.007
CPU Usage: 1.000
Executing actions 100 % done
As you can see, when I run md5sum directly, it only takes about 3s. But if I use vtune (2013update2), it takes about 130s! The analysis result shown in VTune GUI (see the picture attached) clearly indicates that the "getc" function call takes 127s! I wonder if it is a known issue of VTune, or I have to use some correct commandline arguments to get expected getc speed, or it is related to my system configuration (kernel, glibc, etc.).
Here is my system information:
$ cat /etc/issue
CentOS release 6.3 (Final)
Kernel \r on an \m
$ uname -a
Linux yang 2.6.32-279.9.1.el6.x86_64 #1 SMP Tue Sep 25 21:43:11 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
$ gcc --version
gcc (GCC) 4.4.6 20120305 (Red Hat 4.4.6-4)
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ amplxe-cl --version
Intel(R) VTune(TM) Amplifier XE 2013 Update 2 (build 253325) Command Line Tool
Copyright (C) 2009-2012 Intel Corporation. All rights reserved.
Any suggestions are appreciated. Thanks!
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
