Analyzers
5294 Discussions
Very low IPC with VTune and others...
navyant
I've tested vtune with a couple of spec2000 (with reference input) under Redhat 7.3 Linux using a Pentium 4 machine and got follow very low IPC which seems unreasonable. This is the command I put into
vtl activity -duration 300 -c sampling -o "-ec en='Instructions Retired' en='Clockticks':sa=200000 " -app mcf_base.x86_linux,"inp.in" run
17400 = Samples collected due to this event
2000000 = Sample after value used during collection
34800000000 = Total events (samples*SAV)
Clockticks
704881 = Samples collected due to this event
200000 = Sample after value used during collection
140976200000 = Total events (samples*SAV)
So IPC is about 1/4.5 (348/1409)
With bzip, I got a IPC of 1/2. Other benchmarks show a constant less than 1 of IPCs.
Another strange thing is whenever I changed duration, the instructions retired gives different results. I am surely I have run the whole program from the beginning to the end.
Anything wrong with my usage. Thanks!
David_A_Intel1
Recommendations:
1. don't set a duration: VTune will sample until the app exits.
2. don't set a sample after value for Clockticks, the default should be used.
