Analyzers
Vtune Amplifier module build fails on Freebsd11.1
pereira__arun
/opt/intel/sepdk/modules/sep/../../dev/sep/cpumon.c:350:14: error: incompatible pointer types assigning to 'int (*)(struct trapframe *)' from 'int (int, struct trapframe *)'
      [-Werror,-Wincompatible-pointer-types]
    pmc_intr = _PMI_Interrupt_Handler;
1 error generated.
*** Error code 1
Stop.
make[1]: stopped in /opt/intel/sepdk/modules/sep
*** Error code 1
Stop.
make: stopped in /opt/intel/sepdk/modules
Build is currently failing on:
FreeBSD freebsd 11.1-STABLE FreeBSD 11.1-STABLE #0 r328386: Thu Jan 25 04:13:56 UTC 2018     root@releng2.nyi.freebsd.org:/usr/obj/usr/src/sys/GENERIC  amd64
We're currently evaluating Vtune.
Ekaterina_L_Intel
Can you please let know which VTune version/build # you evaluate?
FreeBSD 11.1 support was added starting 2018 Update 3 version of VTune Amplifier and additional fixes coming later in 2018 Update 4.
If you need to get the fixes for early evaluation - please submit support request via https://supporttickets.intel.com
Regards, Katya
