Analyzers
5255 Discussions
Vtune Can't find source but debug info is present
kaplannp
I'm running the Vtune uarch analysis, and I'm trying to double click from a function in the bottom up analysis to the source code location, but instead of showing the source code, it shows only the assembly.
Things I've already tried:
- I've compiled with -g, -g3, -ggdb and all combinations therein.
- Verified that the files have dwarf 4 debug information
- Run other programs that also have dwarf 4 debug information, and had no problems finding the src
- run using the gui analysis configure play button
- run using command line
- tried differnent -O levels
- tried different compiler versions (gcc9 and gcc11)
os is ubuntu 20.04. Vtune is 2024.1.0. Compiler is gcc/g++. Appreciate your help! Here's the makefile:
1 VTUNE_HOME=/opt/intel/oneapi/vtune/latest
2
3 SRC_DIR:=src
4 BIN_DIR:=bin
5 OBJ_DIR:=obj
6
7 CXX = g++-11
8 CC = gcc-11
9 EXE:=gwfa
10
11
12 PROF_UTILS=$(CWD)/../ProfileScripts/RoiCppHeaders
13 MINIGRAPH_DIR=$(CWD)/deps/minigraphKernel
14 CWD:=$(shell pwd)
15 CXXFLAGS:= -O3 -ggdb -g -fopenmp
16 CFLAGS:= -O3 -ggdb -g -fopenmp
17 INCLUDE_FLAGS :=-I$(PROF_UTILS)/include -I$(SRC_DIR) -I$(MINIGRAPH_DIR) -I$(VTUNE_HOME)/include
18 LD_LIB_DIR_FLAGS := -L$(PROF_UTILS)/lib -L$(VTUNE_HOME)/lib64
19 LD_LIB_FLAGS := -lprofileUtils -littnotify -fopenmp -ldl -lz -lpthread -ldl
20 CPP_FILES := main.cpp loadParams.cpp eval.cpp
21 C_FILES := kalloc.c gfa-io.c gfa-ed.c gfa-base.c
22 C_OBJ_FILES := $(patsubst %, $(OBJ_DIR)/%.o, $(C_FILES))
23 CPP_OBJ_FILES_PROF := $(patsubst %, $(OBJ_DIR)/%.prof.o, $(CPP_FILES))
24
25 all:$(OBJ_DIR) $(BIN_DIR) $(BIN_DIR)/$(EXE).prof
26
27 $(OBJ_DIR):
28 mkdir -p $(OBJ_DIR)
29
30 $(BIN_DIR):
31 mkdir -p $(BIN_DIR)
32
33 $(OBJ_DIR)/%.cpp.prof.o: $(SRC_DIR)/%.cpp
34 $(CXX) $(CXXFLAGS) $(INCLUDE_FLAGS) -c -o $@ $^ -DTIMER_ENABLED=1 -DVTUNE_ENABLED=1 -DPIN_ENABLED=1
35
36 $(OBJ_DIR)/%.c.o: $(MINIGRAPH_DIR)/%.c
37 $(CC) $(CCFLAGS) $(INCLUDE_FLAGS) -c -o $@ $^
38
39 $(BIN_DIR)/$(EXE).prof: $(CPP_OBJ_FILES_PROF) $(C_OBJ_FILES)
40 $(CXX) $(INCLUDE_FLAGS) -o $@ $^ $(LD_LIB_DIR_FLAGS) $(LD_LIB_FLAGS)
yuzhang3_intel
By default, uarch-exploration doesn't enable call stack.  You need to click the plus button on the top right corner below and select the box.
yuzhang3_intel
kaplannp
Ah, I see. thank you!
