Analyzers
5272 Discussions
Vtune analyzer (2020.02) does not display the working tabs
drMikeT
I can start Vtune (Intel 2020.02 Intel Parallel Studio XE) and select the project (from the project list that is visible), but when I try to configure the profiling sessions Vtune only shows 3 blank columns .
The systems are Linux Red Hat Enterprise Linux Workstation release 7.9 (Maipo) and CentOS Linux release 7.9.2009 (Core).
Any suggestions?
thanks
Michael
ArunJ_Intel
Hi drMikeT,
Could you please try the latest version of vtune (2021.2). If you are still facing issues could you please attach a screenshot of vtune-gui where the tabs are blank.
Alternatively could you try profiling using vtune command line and try opening results in the GUI as a workaround.
Arun
ArunJ_Intel
Hi drMikeT
As your new issue is related to installation I have moved the message to  "Registration, Download, Licensing and Installation forum".
https://community.intel.com/t5/Registration-Download-Licensing/Re-Re-Vtune-analyzer-2020-02-does-not-display-the-working-tabs/m-p/1273236#M645
About parallel studio cluster edition, the toolkit would be available for download only if you have an existing license for the product.
Arun
drMikeT
We do have company-wide license (Chevron) off a license server and the "INTEL_LICENSE_FILE" is already set before running Vtune.
Do I need to set the "INTEL_LICENSE_FILE" before running the OneAPI installer?
Thanks!
ArunJ_Intel
Hi Michael,
Could you please raise your query about Licenses in "Registration, Download, Licensing and Installation forum".
Arun Jose
drMikeT
Thanks, I will post the question there
Michael
ArunJ_Intel
Hi Michael,
We could see you have accepted the solution to the thread in Registration-Download-Licensing forum, we assume you are able to install the toolkit without issues. With the new version of vtune are you still facing the issue of working tabs being empty.
Arun
ArunJ_Intel
Hi
We are closing the case assuming the issue is resolved with new version of vtune. If you need any additional information, please submit a new question as this thread will no longer
Arun
