Analyzers
Vtune assertion error
Garefalakis__Panagio
Hello there,
I am running vtune in a remote CentOS 7 host for a java application, any idea how to sort out this issue?
Picked up JAVA_TOOL_OPTIONS: -agentlib:amplxe_samplingmrte_javaprof_1.0 -Dsun.boot.library.path=/tmp/vtune_profiler_2020.0.0.605165/lib32/runtime:/tmp/vtune_profiler_2020.0.0.605165/lib64/runtime
Assertion 'jvmti == g_jvmti' failed. Please contact the developers.
<forked VM failed with exit code 134>
<stdout last='20 lines'>
</stdout>
<stderr last='20 lines'>
</stderr>
Adweidh_Intel
Hi Garefalakis,
Thanks for reaching out to us !!
Kindly share the details of java application which you are trying to run in Vtune, also share the steps followed by you.
Denis_P_Intel
Hi Garefalakis,
Are you using ForkJoinTasks in your Java app?
Hello there,
I was using JMH to benchmark a particular part of my application -- unfortunately, JMH does not work with Vtune -- maybe because of its forking behaviour?
Vtune can profile my application perfectly fine without JMH involved and this is what I am doing now -- if there is an alternative to enable JMH I would be happy to discuss it.
Denis_P_Intel
I need to try to reproduce the issue locally to answer your question. If you can provide a simple reproducer that it would helpful.
RashmiP_Intel
Hi Garefalakis,
For debugging your issue, can provide a sample reproducer?
Rashmi
RashmiP_Intel
We haven't heard back from you. Could you please give us an update?
Rashmi
RashmiP_Intel
We have not heard back from you, so we will close this inquiry now. If you need further assistance, please post a new question.
Rashmi
